build a 4G63 in less than ten minutes (vid)
- WANGAN_X
- gsx-lex
- Bicycle
Yeah, he rebuilt it, but never proved it ran again. I was hoping to see it fire up at the end, but was met with nothing.
A cool idea though. Think I'll do the same (document) the work I'll end up doing to my engine at somepoint in its lifetime. Especially the part of, "What connectors connect to what," or, "Where does this hose go?"
AJ
AJ
- gsx-lex
- ldstang50
evo's havent' been doin too bad. no one has complained of crankwalk....yet.gsx-lex wrote:SlowBoy racing should hire that kid, I'm sure he could show them some pointers on how to build an engine.
Why why rebuild a 7 bolt engine though
thats impressive. SBR just needs to die
EVO XTC
i don't have hard drives. i just keep 30 chinese teenagers in my basement and force them to memorize numbers
- bludragontrboawd
bludragontrboawd wrote:it was chattering like amer azn twinkie in the snow!
- gsx-lex
- bludragontrboawd
- gsx-lex
Do a search on dsmtalk for Slowboy, you will see why......
I have a completely stock 6 bolt motor (www.ziptiebandit.com)
Have turbo, will spool.
I <3 Lesbians
I <3 Lesbians
- bludragontrboawd
well your a dsmer so i'mma take your word for it. So you gotta 6 bolt? what year? is it jdm? or no? what kinda set up are you running? i had the whole jdm 6 bolt 50 trim, 650 injectors, 255 high flow fuel pump, front mount, 1g blow off valve, dsm link slow boy clutch which liked to chatter at first...tuned at 21 pounds of psi...
- gsx-lex
I'll brign my car to the meet tonight, if you want to see it for yourself. It's basically a stock 6 bolt (USDM with stock cams etc) , fpgreen turbo, AEM EMS with a hybrid boost comp map, Built BM tranny transmission etc. Check out my website for a complete parts list.
I've dealt alot with many DSM shops and I only goto SBR when it is something specific that only they have (ie turbo quick release lines ).
I <3 Lesbians
I <3 Lesbians
- bludragontrboawd
- gsx-lex
- bludragontrboawd
- bludragontrboawd
- gsx-lex
- gsx-lex
bludragontrboawd wrote:I dont get it.. is slow boy bad?? What did they do?? hmm.. well i guess from there clutch they were bad.. What kinda Engine do you have in your GSX...... lex??
http://www.dsmsource.com/forums/showthread.php?t=126910
I <3 Lesbians
I <3 Lesbians
