build a 4G63 in less than ten minutes (vid)
WANGAN_X
Post by WANGAN_X »
gsx-lex
Post by gsx-lex »
SlowBoy racing should hire that kid, I'm sure he could show them some pointers on how to build an engine :).
Why why rebuild a 7 bolt engine though :notcool:
Have turbo, will spool.
I <3 Lesbians
WANGAN_X
Post by WANGAN_X »
he probably blew it up
AJ711
Bicycle
Post by AJ711 »
Yeah, he rebuilt it, but never proved it ran again. I was hoping to see it fire up at the end, but was met with nothing.
A cool idea though. Think I'll do the same (document) the work I'll end up doing to my engine at somepoint in its lifetime. Especially the part of, "What connectors connect to what," or, "Where does this hose go?"
AJ
gsx-lex
Post by gsx-lex »
WANGAN_X wrote:he probably blew it up
I was refering to why rebuild a motor that notoriously known to be faulty.
I <3 Lesbians
ldstang50
Post by ldstang50 »
gsx-lex wrote:SlowBoy racing should hire that kid, I'm sure he could show them some pointers on how to build an engine :).
evo's havent' been doin too bad. no one has complained of crankwalk....yet.
thats impressive. SBR just needs to die
EVO XTC
i don't have hard drives. i just keep 30 chinese teenagers in my basement and force them to memorize numbers
bludragontrboawd
Post by bludragontrboawd »
You guys dont like slow boy?? i thought they were pretty good. Although when i put there clutch in that they made, it was chattering like amer azn twinkie in the snow! But yeah.. my 7 bolt crank walked and in went the JDM 6 bolt!!!! never had a problem since..
bludragontrboawd wrote:it was chattering like amer azn twinkie in the snow!
:rolllaugh: :rolllaugh:
gsx-lex
Post by gsx-lex »
bludragontrboawd wrote:You guys dont like slow boy?? i thought they were pretty good.
Wrong.....
I <3 Lesbians
bludragontrboawd
I dont get it.. is slow boy bad?? What did they do?? hmm.. well i guess from there clutch they were bad.. What kinda Engine do you have in your GSX...... lex??
gsx-lex
Post by gsx-lex »
Do a search on dsmtalk for Slowboy, you will see why......
I have a completely stock 6 bolt motor (www.ziptiebandit.com)
I <3 Lesbians
bludragontrboawd
well your a dsmer so i'mma take your word for it. So you gotta 6 bolt? what year? is it jdm? or no? what kinda set up are you running? i had the whole jdm 6 bolt 50 trim, 650 injectors, 255 high flow fuel pump, front mount, 1g blow off valve, dsm link slow boy clutch which liked to chatter at first...tuned at 21 pounds of psi...
gsx-lex
Post by gsx-lex »
I'll brign my car to the meet tonight, if you want to see it for yourself. It's basically a stock 6 bolt (USDM with stock cams etc) , fpgreen turbo, AEM EMS with a hybrid boost comp map, Built BM tranny transmission etc. Check out my website for a complete parts list.
I've dealt alot with many DSM shops and I only goto SBR when it is something specific that only they have (ie turbo quick release lines ).
I <3 Lesbians
bludragontrboawd
oh right on.. sounds like good stuff. Yeah i wont be able to make it tonight.. i got class tonight.. But if it was on a thursday.. then i can make it. so hopefully the next one!
gsx-lex wrote:Check out my website for a complete parts list.
What website?
gsx-lex
Post by gsx-lex »
sirwilliam wrote:
What website?
I <3 Lesbians
bludragontrboawd
I was just looking for it and didnt see it either.. hahaha
bludragontrboawd
I FOUND IT .. I FOUND IT!!!!!! Alex seems pretty smart!
gsx-lex
Post by gsx-lex »
bludragontrboawd wrote: Alex seems like a ricer!
fixed.
I <3 Lesbians
gsx-lex
Post by gsx-lex »
bludragontrboawd wrote:I dont get it.. is slow boy bad?? What did they do?? hmm.. well i guess from there clutch they were bad.. What kinda Engine do you have in your GSX...... lex??
http://www.dsmsource.com/forums/showthread.php?t=126910
I <3 Lesbians
