Hey all,
Ok, time has come for one of these so I can control the boost responce The Hydra can do it, but I've heard over and over again it's better to get a seperate EBC. I've been looking at the SBC-iD 3 and the Apexi AVCR. They seem like a little much for me. All I need is something small that can control boost at certain RPM ranges
Idea's anyone?
those are gonna be your best choices for RPM controlled boost, but why control boost with RPM on a AWD car? Also keep in mind that the boost controller is only as good as the Wastegate and spring consistancy and passage diameter both play big factors in boost control. Tell us more about what you are trying to setup?
I personally use a profec spec B (older one with knobs) and I love it!
I believe the company that uses the best boost control technology would have to be HKS. They're EVC series of boost controllers use the quickest stepping motor of any solenoid in the market since last I checked. another benefit is that onece oyu have the solenoid, you can use most of thier controllers interchangably. Most people that I know making serious power uses the HKS EVC EZ as it is cheap reliable and easy to "set and forget". This is the EBC of choice for most dsmers as well as rotary and supra base camps. In fact, this is such a popular boost controllerhtat HKS, brought it back as an "EVC EZ II" model.
The more I think of it, the more I want to just use the Hydra with the Perrin EBCS that I bought. Saves me $$$ for other things
Thanks Zak... You do know, I would lend you that unit if you needed it.
