Find me a rear sway bar...
- Bluestreak2006
Alright I'm looking for a rear sway bar. Wanted to get some feedback from everyone. Im looking for something for the street maybe a few auto x passes. Something to get rid of some of my body roll. Should I go solid or hollow? 22mm, 23mm, ......? adjustable or non? I have an 06 so I think I have the aluminum endlinks so I dont think I need endlinks.
Thanks for the input guys.
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
Gruppe-S has the Cusco 22mm Rear (3-way Adjustable) for $155 shipped. It's what I have on mine (granted, i got mine used) and I've had no problems with it.
http://www.gruppe-s.com/Subaru/subsus.htm
GaToR
drwrx wrote:Gruppe-S has the Cusco 22mm Rear (3-way Adjustable) for $155 shipped. It's what I have on mine (granted, i got mine used) and I've had no problems with it.
I say go cheap.
Since they are all essentially steel bars, and most have similar ~200% stiffness over stock, you might not notice the difference between aftermarket bars, but you will notice the difference over stock.
my cobb adjustable rsb has been great.
fyi, i bent a stock sti rear endlink 90 degrees though with it set on the 'softest' setting. you might wanna think about stronger links.
Last edited by chicken n waffles on Mon Jan 28, 2008 1:57 pm, edited 1 time in total.
- wrxSIN
- Bicycle
I'm just reinterating the above, but if there is any way possible, try to replace the endlinks at the same time. If money is tight, forget I said it, but eventually you are going to want to replace the endlinks. The WRX ones are known to be a little on the weak side. When you add the additional strain of a stronger RSB, the endlinks can crack/break.
+1 on getting better rear endlinks. The stockers are doodoo. Just get a set of KB (or comparable) rear endlinks, install them, and forget about them. Goodbye worrying about rear endlinks!Sabre wrote:I'm just reinterating the above, but if there is any way possible, try to replace the endlinks at the same time. If money is tight, forget I said it, but eventually you are going to want to replace the endlinks. The WRX ones are known to be a little on the weak side. When you add the additional strain of a stronger RSB, the endlinks can crack/break.
- Bluestreak2006
- wrxSIN
- Bicycle
i should but i need to stop spending money on my car lolMr Kleen wrote:and if (when) they fail during (spirited) driving?wrxSIN wrote:sorry about that guys, i didnt realized how late i was with the reply/bump. i plan on getting KB end links when my stock ones break.
replace them when you do the bar. you're already under there and your car may thank you later...
- Bluestreak2006
- Bluestreak2006
- Bluestreak2006
If the weather holds out, I'd prolly be down. I've got lateral links and sway I need to install.Bluestreak2006 wrote:Looks like I will have my endlinks today. Anyone up for a swaybar install this weekend???
(along with a turbo, up-pipe, tmic, fuel pump, heat shield, ecu reflash, auto-dimming mirror, carputer, a/v nav system, etc... Boy, I've got a lot of work to do! )
- Bluestreak2006
- Bluestreak2006
- Bluestreak2006
- Katya4me
