Pic of my Spark Plugs w/ 25K Miles on em
Had them replaced at AndrewTech because they were already out for the compression test.
I've definitely seen worse, but as Will said, it looks like you were running a little lean. Did they mark which cylinders the plugs came from? Can you show us #1 and #4 for comparison?
No they didn't mark em. The rest are here:Sabre wrote:I've definitely seen worse, but as Will said, it looks like you were running a little lean. Did they mark which cylinders the plugs came from? Can you show us #1 and #4 for comparison?
http://www.bsd-unix.net/gallery/v/dcawd ... ?g2_page=6
Yea that's what Andrewtech said, I just posted em here b/c they look cool ;0drwrx wrote:Spark plug 4 is the only one that looks a bit baked, the others look good. It is likely that is the #4 cyclinder as it is the most likely to run lean, but on the whole, it doesn't look that bad. I don't think you have anything to be terribly worried about.
They certainly aren't fouled.
