Pic of my Spark Plugs w/ 25K Miles on em
Phibs
Post by Phibs »
Had them replaced at AndrewTech because they were already out for the compression test.
Bryan
2012 WRX 5-Door Limited
Looks like you were running lean.
I've definitely seen worse, but as Will said, it looks like you were running a little lean. Did they mark which cylinders the plugs came from? Can you show us #1 and #4 for comparison?
WANGAN_X
Post by WANGAN_X »
just a lil lean
Said my n****s don't dance,
we just pull up our pants and,
Do the Roc-away.
Now lean back, lean back, lean back, lean back.
I said my n****s don't dance,
See we just pull up our pants and,
Do the Roc-away.
Phibs
Post by Phibs »
Sabre wrote:I've definitely seen worse, but as Will said, it looks like you were running a little lean. Did they mark which cylinders the plugs came from? Can you show us #1 and #4 for comparison?
No they didn't mark em. The rest are here:
http://www.bsd-unix.net/gallery/v/dcawd ... ?g2_page=6
Bryan
Spark plug 4 is the only one that looks a bit baked, the others look good. It is likely that is the #4 cyclinder as it is the most likely to run lean, but on the whole, it doesn't look that bad. I don't think you have anything to be terribly worried about.
They certainly aren't fouled.
Phibs
Post by Phibs »
drwrx wrote:Spark plug 4 is the only one that looks a bit baked, the others look good. It is likely that is the #4 cyclinder as it is the most likely to run lean, but on the whole, it doesn't look that bad. I don't think you have anything to be terribly worried about.
Yea that's what Andrewtech said, I just posted em here b/c they look cool ;0
Bryan
