Any clues what this is and how I can fix my error??? Thanks
ARGH WHAT FLUID IS THAT???
- GeneralGrievous
Hey guys big dork badge for me but without thinking (emphasis on WITHOUT) I've managed to drain what I think to be my transmission fluid instead of my oil. Despite appearances its not the first time I've changed oil and I'm without an explanation as to why I did it. The bolt wasnt a torx bolt (thought the tranny had one) and was at the bottom of a drain pan to the rear of the front tires and slightly to the drivers side...
- GeneralGrievous
Buy it already!GeneralGrievous wrote:True the fumoto is tempting...
A quick call to Farrish and they said it was the tranny, the fluid was reddish sooooo...
Problem is the only way I can figure to refill it is thru the tranny dipstick in its ever so accessible spot under the IC
Yup, that is where you fill it up. I would just drain all the fluid if you haven't already. Just double check that it was the tranny fluid that you removed
- GeneralGrievous
Don't you have the user's manual? It is in there.GeneralGrievous wrote:How much do you think the MY05 holds? While I'm pickin your brain and all..........
You can also browse www.scoobymods.com
They should have some info.
Kyle@KR-TFab
Zell_06
- spazegun2213
- teh Spaz
go out and get yourself 4 quarts of Redline ATF fluid, and worry about it 50K miles from nowKyle@KR-TFab wrote:3.7 quarts
IN MOST CASES
Green sweet smelling is Coolant
Black is Oil
Red is tranny/diff fluid.
spazegun2213 wrote:go out and get yourself 4 quarts of Redline ATF fluid, and worry about it 50K miles from nowKyle@KR-TFab wrote:3.7 quarts
IN MOST CASES
Black is Oil
Red is tranny/diff fluid Ninja edit: or the blood from working on your car when you skin/shred/tear various parts of your body.
Zell_06
Thanks Alan. Lol Sabre. Getting some of those fluids mixed in with your own is always a good feeling.
Now it says that cars with lower clearances should be careful about ordering the one with the nipple. Are our cars too low for that? Or should I just stick with the regular one w/out the nipple?
- Tony
It doesn't hang that far down from the pan bottom. It does stick out and may rub against the plastic undertray. But as far as it being hit by something, you will have other parts of your car that get damaged if you manage to drive over something tall enough to hit the valve.
I haven't put mine in yet. Waiting to get the cutting torch warmed up to cut a hole through my skid plate.
^^^ And believe it or not, tha makes total sense to me!
