well I have to get them off first. which means I'll have to buy some new pads and do the swap. it may be a month or so before I get it all taken care of, just glad I know now.
Mr Kleen wrote:well I have to get them off first. which means I'll have to buy some new pads and do the swap. it may be a month or so before I get it all taken care of, just glad I know now.
I thought you knew you would need new pads for the upgrade...and shouldn't you always put new pads on w/ new rotors for a fresh start?
I wasn't going to put on new pads, the Carbotec pads have less than 2000 miles on them. was just planning on going through the bedding procedure again.
I may just put on stock 03 pads as the H6 upgrade will shift some braking bias to the rear anyway. hmmm will have to sleep on this...
for the time being. I'm contemplating upgrading to a set of Subaru 4 pots in the front, maybe pairing that with a set of Power Slot Plus rotors. that should satisfy my needs for the foreseeable future.
