oh zak
- spazegun2213
- teh Spaz
oh zak
Gone But not forgotten
^^^ Darrin and Zak are the cause of me spending way too much money!
Zak, you know you want it!!!!
Peoblem is, the goy don't know what it is. Says the block "works with AVCS". Any EJ2 block will work with avcs, that is just a function of the heads. He also says that the JDM 2.5 is better thatn the EJ257, but can't give me the engine code designator, or the differences.
I have been ripped off before, not looking to do it again.
There is an old phrase about a fool and his money. . . but i can't remember how it goes.
I also saw that post last night. I was able to chant my mantra for about an hour and was finally able to NOT respond.
Try to get him to sell you the whole long block for $2,200! You'll save the $700 in parts and labor!
Come on Zak do it . . . it's only money, you can always make more.
For the record, I don't think there is ANY difference between the JDM 2.5 on the forester and the 2.5 on the USDM STi. I have seen a bunch of posts on NASIOC and there has not been any conclusion other than they appear to be exactly the same! I also don't think the seller is claiming that this is "better than" the STi 2.5, just the same.
- spazegun2213
- teh Spaz
man, if i were in town, i would so be like, ok.. let me see it. The odds are he does not know his ass from his elbow about engines.. all he knows is its "jdm" and how "cool" that is.
I think if its good stuff you could take him to town on the price.
lol, you know... You could use a long block too Darrindrwrx wrote: I also saw that post last night. I was able to chant my mantra for about an hour and was finally able to NOT respond.
A quick call/ e-mail to Gruppe-s might answer your question. They get JDM swaps all the time, as per their site:zaxrex wrote:I would love if it worked, but I have to know what about this is diff than USDM. If it is the same set of heads from a v7 or v8, then I can still use my AusDM Utec and ECU. If it is USMD, gotta sell the EM bits.
JDM FXT EJ257 MOTOR
The JDM XT 2.5 EJ257 Engine makes an excellent swap for any WRX owner looking for STI performance from their WRX.
The JDM XT 2.5 EJ257 is essentially an identical engine to its brother the USDM STI 2.5 engine but at a much lower price. The engines feature a completely forged rotating assembly with hyper-cast pistons that is capable of safely withstanding an incredible 500HP.
Compared to the USDM WRX engine, the larger bore (100mm versus 92mm) and increased stroke (79mm versus 75mm) significantly increases the midrange power output and maintains a broad power band even with much larger turbochargers such as the Garrett GT30R. In essence an EJ257 all but eliminates the excessive big-turbo lag associated with the EJ20 WRX. Furthermore the increased displacement helps to increase power output even when using less than optimal fuel, such as California’s 91 octane.
The EJ257’s improvements (over the WRX) continue with the heads and valve-train. With a much improved casting, the EJ257 boasts a larger intake port size, larger compression area, larger valves, and of course more aggressive camshafts.
Given proper tuning and setup, the JDM FXT EJ257 is perfect for larger than stock turbochargers. On average with turbochargers such as a GT30R, we have seen gains of over 50whp and substantial improvements in the midrange power (reduction in turbo lag) in comparison (see graph).
Swapping an EJ257 JDM FXT into a USDM WRX is a straight-forward process. The intake manifold is simply switched over (along with injectors, rails etc.) and the engine is dropped in. The custom cam-position sensor (we supply this) is bolted into place with the factory cam-position sensor, and the FXT cam-position and AVCS sensors are left unconnected. ECU recalibration is required for this particular engine.
We offer in-house installation, setup, and professional dyno-tuning, including ECU reprogramming (Ecutek) and stand-alone engine management installation. Please contact us for any questions regarding our services.
ABOUT OUR ENGINES:
All our engines are inspected, leaked down, and compression tested. These particular FXT motors are all less than 1000km and are practically brand new. You MUST follow standard break-in procedures on these engines (500km). We offer start-up warranty on all our engines.
$2999 Shipping and crating is additional
Yeah, I gave that same site to Alex and said that if he is selling what is pictured from the Gruppe S site, I would pay to have a leak-down test done on it so I could see the results. If everything is as advertised, I'd drive on up and take a look for myself.
<Peer pressure> Come on Darrin, you know you want one...
The problem is not with the wanting . . .
It's with the getting!
Let's do the math: (all numbers are estimations)
2.5 long block: $2,500-$3,000
Install: $1,600-$2,000
ECU: $800
UTEC (or other EM): $800
Turbo (SZ55 or FP Red): $1,400-$1,500 (or $250 to turn vf22 into pe1820)
Bigger injectors: $300
Dyno Tune: $400
Are you beginning to understand?
Now throw in the fact that my transmission won't hold out long with that kind of power, and a STi tranny runs around $3,000 plus $1,000 for install.
What's the old saying, "a million here a million there soon your talking real money!"
ECU: $800
Dyno Tune: $400
Sorry Darrin,
I didn't mean to get ya all worked up. I'll try and bring you back down gently...
Remember, with increased torque, comes increased strain on gears. The stock five speed has well documented physical limits. If you get a 2.5 it will be a matter of when, not if your second gear explodes. Add the cost of RA gears (1200 or so UNinstalled) or a PPG 1-4 (5-6K, IIRC) to the initial purchase price of the motor (2K), plus installation (another 1-2K) and you're looking at quite an expensive venture.
Did that help at all?
(i'd probably still do it though)
While the first two are very true, there is big difference between a $7,000+ 2.5 engine swap and $800 turbo/injector/fuel pump swap.Mr Kleen wrote:speed costs money: how fast do you want to go?
want to make a small fortune in racing? start with a large one.
my WRX doesn't need to be ANY faster.
A vf30/34, pinks and pump would net you (stock WRX) around 50-60 whp. That's around $16-$13 per whp and can turn a 6 second 0-60, 14 second 1/4 mile @ 90 mph stock WRX into a sub 5 second 0-60, 13 second 1/4 mile @ 105mph EVO/STi challenger, which is a steal in the world of speed.
Granted, the injector install is a pain, but I'm sure you could find some help from the those of us who have gone before you.
Again, I'm not trying to push you, and if your satisfied with your current power, than congrats, your a better man than I. However, the cost of a turbo/injector/pump swap is about the same cost as a set of wheels and tires or springs and struts or a turbo-back exhaust or a set of headers and a big TMIC or engine management or a big brake kit or . . . well, you get the idea.
yeah, I hear you! but my budget is a lot tighter than some of the people here. I have to do a lot of cost/benefit analysis before I make purchases (even with no wife to hold me back). this car has to be my everything and so far she's gangbusters.
when I do get the sickness, I know who to turn to.
now about looting your dumpster for that old BBK you're going to throw away when you get your '06...
Yeah, that is what I'm thinking. BTW, I have the JDM v7 ECU and the AusDM Utec the get away from the higher impeedence injector and other sensor issues and allow the AVCS to work. It works on paper.drwrx wrote:If he is willing to sell the entire long-block for $2,000 or so and it's in good shape that's worth it. Any word as to whether your ECU and UTEC will work with it?
How does that work w/ the OBDII emissions check?zaxrex wrote:drwrx wrote:BTW, I have the JDM v7 ECU and the AusDM Utec the get away from the higher impeedence injector and other sensor issues and allow the AVCS to work. It works on paper.
