Just another S2k?
cheshirecat
Unicycle
Just another S2k?
Post by cheshirecat »
Do you like Weight Dist. or Sick Power?
DISCLAIMER: The new guy doesn't know if this is a repost or not. Admins do your worst if it is.
Brandon
05 WRX STI
03 WRX Wagon
Racing, because all other sports require only 1 ball.
Nope, it hand't been posted. What are the numbers though? Pic's look great, but I want to know what the beast really does!
spazegun2213
teh Spaz
Re: Just another S2k?
Post by spazegun2213 »
cheshirecat wrote:Do you like Weight Dist. or Sick Power?
meh, there is no mention of total weight there or of the power its making. When you are making 800+ hp and weigh in the 1500-2000lb range, THEN I'll get all excited ;) weight distro be damned, if you have wide enough tires it does not matter 8)
haha, nice project though, i bet it goes too!
Gone But not forgotten
isn't the 2JZ a Toyota engine? I also couldn't find numbers but I just did a quick scan.
Post by WRXWagon2112 »
Restricted page?!
I guess the DoD doesn't like FiftyFiftyRacing. :(
cheshirecat
Unicycle
Mr Kleen wrote:isn't the 2JZ a Toyota engine? I also couldn't find numbers but I just did a quick scan.
Yes, it is the quintessential Toyota engine and one of the best flowing/strongest engines in the world
2JZ-GTE Twin turbo, iron block, capable of 800-900whp on the stock block
They are buildng another s2000 and shooting for 1200whp :shock:
Seems a bit far into the arena of ridiculous but hey.....can't have enough POWAAA
I have a million questions I want to ask those guys!!!
Aside:
I disagree with bigger tires will counter weight distribution. If 70% of your weight is forward in anything other than a drag car (FWD drag cars weight over front tires) you are *going* to have massive understeer.
$.02...
Brandon
05 WRX STI
03 WRX Wagon
Good lord, if that S2k had 800RWHP, I can't imagine what a pita it would be to drive... Would be fun in a straight line though!
WANGAN_X
Post by WANGAN_X »
i would assume less then 300 whp in its current trim 9 psi is less than stock, and no way in hell a s14 rear end is going to hold that kind of power...
WANGAN_X wrote: and no way in hell a s14 rear end is going to hold that kind of power...
That's what I was thinking...
cheshirecat
Unicycle
I wonder if they are really using the s14 rear end or the common swap for the s14: infiniti j30 lsd (3.96). The stock s14 rear is an open diff. However, there are a very few 240s with a stock lsd (4.10).
If my assumption is correct, the j30 rear end or even the 300zx TT rear end are both quite capable of handling a lot of power...
Brandon
05 WRX STI
03 WRX Wagon
gsx-lex
Post by gsx-lex »
I'd be more impressed if they were making that power on a s2k motor.
Take that motor and put it in falafel and you'd have the world fastest falafel.
Have turbo, will spool.
I <3 Lesbians
gsx-lex wrote:Take that motor and put it in falafel and you'd have the world fastest falafel.
:lol2:
cheshirecat
Unicycle
Falafel?
falafel? do we make falafel?
Brandon
05 WRX STI
03 WRX Wagon
falafel is tasty!
WANGAN_X
Post by WANGAN_X »
extreme in MD made 730whp on there s2k... i believe they still hold the record for 1/4 in a s2k
