Goob's Saabaru part II
Re: Goob's Saabaru part II
What would happen if I ran without an EBCS vs running an EBCS with the map Julian did for you? Would that map need to be reworked if I ran an EBCS?
Will I need a walbro fuel pump?
Also, DP arrived!
Also, DP arrived!
You could not run my MAP with a 3 port. It would HAVE to be redone. I don't know anyone who has, but I would expect the turbo would overboost like crazy.
The wastegate parameters change when any solenoid change occurs. In ROM Raider, you set the wastegate parameters with maximums. Most 3-port EBCS will allow boost levels of 80+lbs of boost, whereas the stock 2 port gets a bit flaky at much above 18 lbs on the smaller TD04 sized turbos, and 21 lbs on the vf39 / 43 / 48 / 52 series turbos. Or it may not let them reach anywhere near that threshold. Like mine or Jason's.
With my current map and a the stock 2 port bcs I'm hitting just over 15lbs and dropping to just under 14lbs. I also have my wastegate actuator about as tight as it gets.
You will not need a fuel pump unless you go to a lager turbo, and then you would need larger injectors as well. A path I cannot recommend.
So, no need to get an ebcs yet if I use your map?
just need to order the headers and find a STI splitter
If you are going to use my MAP, I would not let the splitter stop you from installing the rest of your parts.
If someone brings a Tactrix and Julian has the MAP and his laptop, you can just flash and go.
Pick-up the splitter whenever.
Splitter on its way...
just want to make sure I do not need the EBCS?
You do not NEED it.
If you want to run maximum boost with maximum stability, than it is worth having.
Tires are in and look awesome, but so skinny...I miss my 245s
- Raven
- Mr. Underpowered or something
I'm rocking 185s
2013 Mazda 2
1994 Chevy S10 pickup
2013 Mazda 2
So who would be willing to lend a hand with the stage II madness install?
I have a heated oversized 2 car garage out near Clifton that we can do the install.
If you can help me source a propshaft and bearing, I'm in.
After doing more research I am going to skip the headers...so I am ready to go stage 2...all hands on deck!
I am looking at the Grimmspeed Subaru Exhaust Gaskets
22% Thicker than OEM Gaskets with a 304 Stainless Steel Fire Ring
Package Contents:
•(2) Engine to Exhaust Manifold Gaskets
•(2) Exhaust Manifold to Crosspipe Gaskets
•(1) Exhaust Manifold to Up Pipe Gasket
•(1) Up Pipe to Turbo Gasket
•(1) Turbo to Downpipe Gasket
•(1) 3" Downpipe to Cat-Back Gasket (don't need since I am keeping the stock cat and have another 2.5" gasket)
Is this all I need?
Package Contents:
Is this all I need?
Wow, going through all that work just to put gaskets on a stock exhaust?
If you are hell bent on doing that, then at least save yourself some work and leave the crossover section alone and don't touch those gaskets.
If the stock gaskets are in good condition I will let them be.
By the time you 'check the gaskets', you have already taken the pipes apart and might as well replace them.
okay...I have all the goodies to go stage II
STI up pipe
Bosal shorty dp
STI TMIC
STI splitter
Autometer pro comp boost gauge
WRXtra boost gauge instal kit
GT SPEC gaskets (2x header, header/up, up/turbo and turbo/dp)
Who can lend a hand and when will be good for you?
I also bought new rotors and pads...may come in handy
STI up pipe
Bosal shorty dp
STI TMIC
STI splitter
My weekends suck right now
If I get one free, I'll try to lend a hand!
- TRANS4M
- Tricycle
Just let me know the date and I'll try to make it work.
- 2011 SWP WRX Hatch limited
I will not have a weekend free until mid January.
might be picking up a Tanabe Medalion Touring CBE for the Saabaru. The STI CBE is just too quite
- TRANS4M
- Tricycle
How are the brakes treating you?
Brakes are great!
dipped my wheels and added a Thule rack...basket and bike rack coming soon.
- iceyinferno
You might just want to look for a 2.5" intermediate pipe. Daddy's has the Stromung piece for $158.goob_os101 wrote:might be picking up a Tanabe Medalion Touring CBE for the Saabaru. The STI CBE is just too quite
http://www.daddysscp.com/Stromung_2_5_I ... sw500x.htm
Once you put the shorty down-pipe on, the exhaust note will open-up noticeably. And you say your mid-pipe cat is gutted as well.
Trust me, you will want some muffling in there. And while the Tanabe Medallion isn't a really "loud" exhaust, it isn't quiet either. Especially not running completely catless.
