Goob's Saabaru part II
goob_os101
Post by goob_os101 »
Here she is:
Parts installed:
Mach V Springs
Parts not installed:
STI CBE
STI TMIC
Parts needed:
Downpipe
Up-pipe
Silicone turbo inlet
Sways and endlinks
Tune
Struts...maybe...Dan was telling me the Stock struts work fine with the Mach V springs.
Tuning question...what do I need to go stage 1? I have been out of the Subaru world for too long.
Re: Goob's Saabaru part II
goob_os101 wrote:what do I need to go stage 1? I have been out of the Subaru world for too long.
You can go stage 1 right now. Most stage 1 maps are "stock" no mods.
Down-pipe and up-pipe are what you need for stage 2.
I'd say get the down-pipe and up-pipe and y-pipe in and then get the MAP.
goob_os101
Will I run into issues with inspections with a catless DP?
You might. I run a shorty down-pipe so I keep the 2nd cat in place on mine. I have yet to have an issue. Your mileage may vary.
When it comes to emissions, I've never had an issue with the visual as they usually just do the OBDII test.
goob_os101
Is this the header/uppipe I should be looking at?
http://www.ebay.com/itm/Manifold-Header ... 66&vxp=mtr
Yep :) Get new OEM gaskets or Grimmspeed gaskets too. You could probably reuse your old ones, but I error on the side of safety.
Agree with Sabre on this. Also, you might want to pick-up some up-pipe studs. The ones that come with that up-pipe will likely not fit well. I have seen that twice now.
But who knows, you may get lucky.
goob_os101
Weel I can grab a STI up pipe for $50 off a local guy...should I buy just the header?
also, I may get one of these plates too
Grab the STi for $50.
The headers are up to you. A set w/o the up-pipe usually run $120 shipped.
They are usually good for 12-14 whp and 16-18 lb/ft.
The up-pipe is not an easy install, the headers are a breeze by comparison.
If you're going to do headers, do the up-pipe at the same time.
You don't really need a tune for them but you absolutely will when the down-pipe goes on.
(http://www.daddysscp.com/Stromung_Divor ... 1000-3.htm) $190
goob_os101
I would like to do the whole kittenkaboddle (DP, UP, and Headers) at the same time. Any recommendations for shops and prices or I could host one helluva install day?
goob_os101
EB Stores has a set for $95 shipped:
http://www.ebay.com/itm/Stainless-Steel ... 11&vxp=mtr
goob_os101
Will this GM 3port boost control solenoid work for me?
http://forums.nasioc.com/forums/showthr ... ?t=2395891
Also, Mach V has thier own:
http://www.fastwrx.com/mavbocoso.html
also, I found out the 92x group uses a stock STI TMIC splitter with a bit of cutting.
I picked up the STI Up pipe and I am currently working on a Bosal Shorty DP
One of the Ebay stores totally screwed-up Julians order.
Whichever one that was, avoid it like the plague.
As for the BCS, I'm sure either will work, but you will need a tune for it to work properly.
Keep the stromung shorty on you search list as well as the bosal. Either will do the trick.
psmwrx
Post by psmwrx »
With the header off the up-pipe is not that bad. You just need the right tools. Good sockets, extensions, PB blaster and maybe a breaker bar. If others are willing to help I could make space at my house for it to get done.
2004 WRX Wagon (Project)
2011 F150 Lariat (Parts hauler)
1989 Ford Bronco (The other B***h)
goob_os101
Thanks for the offer!
I have a huge 2 car garage out in manassas...and it does have heat in it...so If I can coax some peeps to come lend a hand once I have the parts.
goob_os101
The guy wants $75 for this Bosal shorty DP, but look at the dent...will have any huge impact on performance?
That dent is only on the wastegate side and should not affect performance at all.
I don't care what vanity plate you get, but you need to change your avatar.
:bfg:
There can be only one!
goob_os101
Mr Kleen wrote:I don't care what vanity plate you get, but you need to change your avatar.
:bfg:
done
Bosal DP on its way.
Next up:
Turbo Inlet
STI Splitter
Headers
EBCS
Tune
THERE CAN BE ONLY ONE!!1! :rolllaugh:
I had a Bosal DP. Would have been perfect if I hadn't put header wrap on it. After the weld was repaired I removed the wrap and it's still on the car AFAIK...
I concur, don't wrap your down-pipe. It looks like it has been coated and that should be enough.
Both of the shorties on my WRX & FXT are coated. I did it myself with VHT 2000. They make a noticable difference and have held-up very well.
By turbo inlet I hope you mean Intercooler Y-pipe. But if you already have an STi TMIC you don't need a Y-pipe. You will likely need a 90-Degree Elbow as seen here: http://fastwrx.com/90elco.html
The turbo inlet is a HUGE PITA to install and not worth the time or money on a stock turbo car.
You can get tuned before you get the splitter installed as well.
goob_os101
The STI TMIC I have came like this:
So, looks like I am good to go there and I will abandon the turbo inlet then.
Also just orederd a set ofGeneral G-MAX AS-03s...They look a good fit for my needs.
http://www.youtube.com/watch?v=IvLStRd0 ... r_embedded[/video]
I also read on NASIOC where Dan (Mach V) spoke to a Continental corporate guy at a SEMA show asked for an all-season with the traction properties of the Conti DWSs, but with a stiffer sidewall. He said the General Gmax AS-03 was the same tread compound, but with a sidewall aimed at a more performance-oriented customer :drool:
It looks like you're set for the TMIC.
What size are the Gmax AS-03s?
Remember, the wagon doesn't have the flared fenders so 225s will often rub. 235+ will most certainly.
Also, if you want to try my MAP first w/o the ECBS you are welcome to do so.
goob_os101
Tires are 205/55/16.
