THE ALL-NEW SUBARU FB ENGINE
I was very disappointed to see that it does not have Direct Injection... This is for the non-turbo version though, so maybe the turbo version will have DI. The change to rocker arms is very interesting, as is the new exhaust routing and the change over to a single overhead CAM. The newer stroke does make it a more "square" engine design.
Code: Select all
2011 FB 2010 EJ
Displacement, cc (cu in) 2,498 (152) 2,457 (150)
Bore/stroke, mm (in) 94.0/90.0 (3.70/3.54) 99.5/79.0 (3.92/3.11)
Peak horsepower, @ rpm 170 @ 5,800 rpm 170 @ 6,000 rpm
Peak torque, lb-ft @ rpm 174 @ 4,100 rpm 170 @ 4,400 rpm
Compression ratio, :1 10.5 10.0
Fuel requirement Unleaded gasoline (87 octane) Unleaded gasoline (87 octane)
Valvetrain configuration 16v, double overhead camshaft 16v, single overhead camshaft
