GENERATION II COPPER HEADER WRAP
Titanium Wrap with LR TechnologyGeneration II Copper Header Wrap improves heat resistance up to 30% more than current technology, by utilizing a new proprietary coating developed by Thermo-Tec; improved Thermal-Conduction-Technology (T-C-T). Generation II Copper Exhaust Wrap creates more horsepower and reduces under-hood temperatures, increases exhaust scavenging, withstands continuous heat up to 2000ºF, contains no asbestos.
Constructed from pulverized lava rock, extruded into fibers and then woven into a tight weave gives this material titanium-like strength and toughness. This improvement in thermal protection helps reduce underhood temperatures resulting in cooler air intake for improved performance. And less heat in the engine bay means reducing the chances of “heat soak” conditions on vital underhood components.
Titanium Wrap is extremely durable and capable of handling more heat than any other wrap found in the market today. Typical glass fiber wrap is rated at handling 1200 degrees F of maximum direct heat, while Design Engineering’s new Titanium Wrap, using LR Technology, is capable of handling direct continuous heat up to 1800 degrees F and radiant heat up to 2800 degrees F. And because it’s pliable, there’s no need to wet the wrap when wrapping headers or pipes as many do in order to make the wrapping process easier to manage and to get a “tight” wrap
I just ordered the Ti Wrap for my new headers, so I'll post up a review soon
