An interesting storage server
Server 1 - Looks like a direct competitor with Sun's Thumper... only at a LOT cheaper price point.
Code: Select all
Model	                  AR442F4
Form Factor               4U Rackmount
HDD Trays                 42 Hot-Swappable 3.5"
RAID Level                0, 1, 1+0, 5, and 6
Maximum Capacity          84TB
CPU                       AMCC 440SPe
Memory                    512MB, Upgradable to 2GB DDR-2 ECC SD-RAM Memory
Auto Rebuilding           Yes
Hot-Spare                 RAID 1, 1+0,  5, 6
Host Interface & Transfer Rate Dual Fiber Channel (4 Gbps)
Drive Interface           SATA II
Cooling Fan                2 x Blower Fans
Power Supply              600W x 3 Redundant Power Supply Modules
Control Interface         LCD Panel, RS232, RJ-45 Ethernet
Status Indicators         1 LED / HDD
Dimension (in)            7"H x 19"W x 30.7"D
Weight (lb)               100 (w/o hard drives)
Limited Watrranty         2 Years
Re: An interesting storage server
I built a super high speed storage solution around one of their older products a couple years back... I think that one was a 2U that held a dozen or so drives. Stoopid fast. :) And pretty solid. Had more problems with the server the FC was attached to than the array itself.
Ah, so this is (kind of) is what you ended up using for that! We were looking at the Sun Thumper(mentioned above) for awhile for a project, but ended up doing some other things. We might require one of these for testing purposes though, haha.
