First remove the top bolt from the hood hinge (12 mm) and then the middle fender bolt (10 mm)
Next, attach the top bracket to the top hole of the hood hinge using the supplied bolt (#5 Key). The flat side of the bracket should be facing the front of the car and the ridge side should be flush with the hood/hinge. Next, use your shoulder or extra set of hands to hold the hood up and screw the bottom bolt in (Open 10mm wrench)
Luckily, one of the dampers is strong enough to hold the hood up while you install the other side.
The hood also about an inch higher than stock height. I can't recommend IXIZ Concept's products enough. I've had to contact him a few times about the SClutch kit and future products. Each time, he has been very nice and friendly. He has a few more thing on his site I might pick up too.
