Running the Cisco ASA OS in a VM
Haven't tried it yet, but might later tonight. Interesting way to try out changes before going live with them!
[url=http://asa_project.gromnet.net/]Project URL[/url]
Install
Live version -
When you get into the linux prompt, type /asa/bin/lina. For the serial pipe, in vmware for serial port settings chose “use named pipe”, “\\.\pipe\vmwaredebug”, “This end is client”, “The other end is application”.Then download “vmwaregateway.exe”, start it with vmwaregateway.exe /t, use putty to connect to localhost, port 567.
Now start virtual machine, press enter on boot, switch to previously started putty and type /asa/bin/lina.
If you want the image to work in real pc instead of vmware be sure you have PCNET, Intel/Pro 100 or Intel/Pro 1000 card.
Re: Running the Cisco ASA OS in a VM
definitely playing with this one tonight. thanks!
i've been goofing and using switches and commands that were depreciated with the older pix devices... :oops:
lol, I keep trying router commands one them... most work, but the important ones don't, haha.
that's interesting... i have to admit i winced a bit when i saw the subject, but... interesting... will have to try it out.
schvin wrote:that's interesting... i have to admit i winced a bit when i saw the subject, but... interesting... will have to try it out.
lol, I'm not suggesting you do this for production, don't worry ;)
It does help if you're trying out configs.... or looking at the OS image...
Hmmmm... I wonder which one you were doing when you stumbled across this...
haha, yeah, but still. i agree with your suggested use cases though :P
