New 3" CBE on the way
Posted: Thu May 14, 2009 10:22 am
by goob_os101
Re: New 3" CBE on the way
Posted: Thu May 14, 2009 10:39 am
goob_os101 wrote:Purchased an Ebay(SurewinProducts) V2 Catback
reviews:
http://forums.nasioc.com/forums/showthr ... ?t=1708267
only issue I have is that I snapped one of the exhaust Spring bolts. I know its best to have that lil bit of flex, so where can I get a replacement?
Nice. Looks like a shiny COBB/Stromung knockoff...get a new spring bolt at the dealership (assuming you are utilizing the donut flange, otherwise, you should just be using standard bolts.
Posted: Thu May 14, 2009 1:43 pm
by thermobox
congrats. sounds and looks good.
Posted: Thu May 14, 2009 2:25 pm
3 things:
1. Based on what I have seen / read in the posts on this exhaust you won't be using your spring-bolts to mount this to your Mid-cat pipe.
Just remove the donut gasket and mount the flanges flush. Try the gaskets that come w/ the exhaust, but if it doesn't seal properly use some "Mr. Gasket" (thick gasket material looks like cork) cut out a template using one of the gaskets that come w/ the exhaust.
2. That is a very loud exhaust. It is very similar to (if not the same as) the exhaust on my FXT and before I put the auger in, it was CRAZY loud. Like hear me coming 3 blocks away loud. If you find yours to be similar Get this:
http://www.speedwaymotors.com/Speedway- ... ,1736.html
It's $15, slides into the pipe between the mid-pipe and the axle-back section. It has no noticeable effect on power and will take the raspiness and droning out of the exhaust.
3. Get the Kartboy XL hangers. Trust me, do it. It will melt your bumper.
Posted: Thu May 14, 2009 3:06 pm
by goob_os101
Thanks for the advice guys.
It won't stay shinny for long. I will most likely use VHT flame proof and make it flat black. I will leave the tip shinny.
Posted: Wed May 20, 2009 1:14 pm
by goob_os101
FEDEX says it will be delivered today...I so exited
Posted: Wed May 20, 2009 3:21 pm
goob_os101 wrote:It won't stay shinny for long. I will most likely use VHT flame proof and make it flat black. I will leave the tip shinny.
good idea. More stealth. I did that w/ my prodrive exhaust and it looks more stock looking.
Posted: Wed May 20, 2009 4:04 pm
by goob_os101
Yip the Wifey confirmed the it is here! Just worried about the fitment...hopefully it doesn't sit high.
Posted: Wed May 20, 2009 4:19 pm
goob_os101 wrote:Yip the Wifey confirmed the it is here! Just worried about the fitment...hopefully it doesn't sit high.
Do you have a trailer hitch? If so, you'll
need longer hangers.
Did I spell that right?
Posted: Wed May 20, 2009 4:33 pm
goob_os101 wrote:Just worried about the fitment...hopefully it doesn't sit high.
I would try to mount it straight w/o removing the donut gasket and see how the bolts fit.
Next, I would remove the donut gasket and try mounting it flush w/ the flat gaskets provided.
It it won't seal properly than use Mr. Gasket.
I also agree that you will want long hangers.
Go ahead and bolt it up, but if it touches at all (or even comes close) get it off and get the long hangers.
Posted: Wed May 20, 2009 9:13 pm
by goob_os101
Tried to install but failed.
1. Put 2 xl hangers on the muffler and cant get the stock hangers to connnect by the cat and by the axel
2. They send 2 bolts that are too big to connect stock cat to mid pipe
Fuuuuuuuuuuuuuuuuuuuuuuuuuuu!
Posted: Thu May 21, 2009 9:55 am
by goob_os101
ordered a set of Karyboy XL hangers from IAG...should be here tomorrow
Posted: Wed May 27, 2009 8:49 pm
by goob_os101
installed!!!!!!!! pics on 1st post
Love it!
Posted: Wed May 27, 2009 10:00 pm
Looks great man, congrats!
Posted: Wed May 27, 2009 10:54 pm
looks good. you still going to spray it with the VHT?
Posted: Wed May 27, 2009 10:59 pm
by goob_os101
I think I will do the pipes and muffler and leave the tip. It is really shinny!
Posted: Wed May 27, 2009 11:38 pm
just do the back of the can. the rest will be dingy in no time.
Posted: Thu May 28, 2009 7:35 am
Very nice!
Posted: Thu May 28, 2009 7:59 am
Looks good. Fitment looks perfect. If it isn't too loud, I would say this is a huge win!
Posted: Thu May 28, 2009 10:55 am
Looks good.
goob_os101 wrote:I think I will do the pipes and muffler and leave the tip. It is really shinny!
I concur w/ this decision and feel it necessary in these parts.
