1) What is involved with resetting the ride height (computer)? Is BMW hooking up a cable and flashing adjusted software? Or is there a special button that you hit (or ODB / Ubus [edit: CAN bus] signal that you set) that just sets the current sensor height to the default?
2) What angle is the front cv shaft at on a e92 335 XI (wheel vs shaft-to-the-wheel), when standing around with the stock suspension? What is the length of the shaft from front diff to wheel?
3) How do you check what version of DME and software you have?
4) What did BMW change in model year 09' for the e92 335 xi suspension. It is not the same... feels more planted than 08' XIs. Did they stealth-implement the sport suspension for the XI sport package models (previously you only got seats + steering wheel with SP on XIs)? Or is this all the effect of widening the wheel base by 3"?
5) Are the rumors of the latest software version having even more aggressive anti-piggyback measures true? (I've heard "no problem" from some tuners, and I've heard "this thing got detected in 2 seconds flat" from some users).
That's about all I can think of for now
-scheherazade
