Turbo for WRX
- Unicycle
Turbo for WRX
Okay so I finally have recovered slightly from the dent my engine made in my wallet. So now what i am wondering is, do i go with an 18g or with a 20g, what are the ups and downs of either, what do i need to do before installing either of these larger turbos, and what is the cheapest price i can get it all done for? Thanks!
2004 335 AWHP WRB WRX Stage 4
2005 525 AWHP AW STi
- Unicycle
Re: Turbo for WRX
Oh by the way, I already have somebody helping me put it in who works for subaru so that is not a problem i just need to know what all needs to be put in at the same time and what it would probably cost!
- wrxSIN
- Bicycle
Re: Turbo for WRX
injectors, fuel pump, boost controller, tune, full exhaust, topmount or front mount, intake, and i think thats pretty much everything you need, except the turbo of course.
You also said something about an engine? if its a 2.5l youre in luck, but a 2.0l = mega lag
ilike2startnewthreads
Re: Turbo for WRX
For an 02, if you want something quick spooling an 18G with a 7cm housing would work beautifully. Doesn't feel must different than stock. 20g will offer you more hp but at the cost of some lag.
Re: Turbo for WRX
I just did a 16g swap. there is a little lag now but a lot more power. being a street driven car I'm not sure that the swap was worth it, it was already fast at stage 2. but I guess I'm in the minority with that opinion around here.
things you will absolutely need:
Turbo
Injectors (PITA)
Fuel Pump (easy install, if you don't mind smelling like gas for 2 days)
DP
EM (with the right EM you won't need a boost controller)
oil/filter change
coolant (to refill what you spill during the swap)
things that would be nice:
UP
full TBE (3")
Turbo Inlet (PITA)
Intake (I recommend the K&N typhoon)
larger TMIC or FMIC (TMIC has less lag; FMIC is for track use or if you like the look)
professional dyno tune
Turbo
Injectors (PITA)
DP
oil/filter change
UP
full TBE (3")
Turbo Inlet (PITA)
- Unicycle
Re: Turbo for WRX
Okay so I really dont want to pay more than $500 for the turbo alone, the other pieces i am not worried about i can get them from a friend but i am trying to stay $500 or under for the turbo... if necessary i will go higher but for now just browsing that price range... so with that said:
Anybody have any opinions about this turbo? never seen it before just came across it and was wondering... would my 2.0 be able to handle this turbo? what all would be needed and is this in fact even a good turbo?
http://cgi.ebay.com/ebaymotors/JDM-SPOR ... 0272117519
Re: Turbo for WRX
To be perfectly blunt, NO.02SilverWRX wrote:Okay so I really dont want to pay more than $500 for the turbo alone, the other pieces i am not worried about i can get them from a friend but i am trying to stay $500 or under for the turbo... if necessary i will go higher but for now just browsing that price range... so with that said:
If you're worried about only spending 500 on the turbo, get a VF39 or VF43 off of an STi, period. The only other options in your price range would be a used 16G, VF30 or VF34.
Re: Turbo for WRX
I have a VF22 if your looking for something like that. let me know and I will get back to you with a good price.
- Unicycle
Re: Turbo for WRX
Hmm... So how much more would i need to spend to get a decent 18g turbo that is going to give me a noticeable gain in power? Also is it even worth it to have an 18g on the 2.0 WRX motor?
Re: Turbo for WRX
That's HUGE turbo. Take a look at the spec's listed on the page:02SilverWRX wrote:would my 2.0 be able to handle this turbo? what all would be needed and is this in fact even a good turbo?
Here is a good used VF39. Make sure to ask about shaft play in any used turbo. It shouldn't have any forward/backward or side to side.Application: Ideal for large (3.0L-6.0L) displacement engines
What are you going to be using this turbo for? Keep in mind that VF turbo's are rebuildable, whereas the 16/18g's are. This could come up if you plan on keeping the turbo for awhile
- Unicycle
Re: Turbo for WRX
LOL LOL LOL... I accidentally posted the wrong link to that turbo. Yeah i know that one is too huge, i dont know where to find the turbo i was looking at but i know that was the incorrect link. Well i found a guy last night while i was out who has an 05 STI and he swapped the VF39 out of his girlfriend's STI and he doesnt know anything about the cars so i told him that his VF39 is only worth $150-$200 max and he said if i can find somebody to give him $200 he will sell it so i think i am going to get that one from him, it has 15 k miles on it and it looks brand new...
Re: Turbo for WRX
1.) I'd tell him the truth.... if he finds out later it was worth more, he might not be so nice...
2.) Make sure you play with the shaft!
Re: Turbo for WRX
I have a 16g.
Re: Turbo for WRX
My bad!
