MFin sunroof
Posted: Wed Jun 04, 2008 3:03 pm
by spazegun2213
you know, I 've never had a sunroof till i got the bimmah. Once i had one, i loved it, i leave it open to vent hot air during the day and its nice and cool when i get in it after work. But today, like so many days I've had to run though the pouring rain. So now I'm soaked, and all in the name of trying to save my car from becoming a fish bowl. Now i remember why I hate sunroofs!
Re: MFin sunroof
Posted: Wed Jun 04, 2008 3:18 pm
Manual convertible top ala Miata is the only way one should deal with the sun in a car.
IMHO.
Sorry you got soaked.
Re: MFin sunroof
Posted: Wed Jun 04, 2008 4:07 pm
by moxnix
complacent wrote:Manual convertible top ala Miata is the only way one should deal with the sun in a car.
Of course if you leave those down in the rain you have even more water to deal with.
moxnix - still wet from leaving the top down yesterday.
Re: MFin sunroof
Posted: Wed Jun 04, 2008 4:42 pm
Re: MFin sunroof
Posted: Wed Jun 04, 2008 4:56 pm
by chicken n waffles
Re: MFin sunroof
Posted: Wed Jun 04, 2008 5:31 pm
by schvin
ha, d'oh!
i do miss the t-tops on my mr2. ah well.
Re: MFin sunroof
Posted: Fri Jun 06, 2008 6:20 pm
by ElZorro
I have an aftermarket Webasto in my FXT... automatically closes when you turn the car off, and if you don't want it to you hit one button and it stays open.
Re: MFin sunroof
Posted: Fri Jun 06, 2008 8:13 pm
by WRXWagon2112
ElZorro wrote:I have an aftermarket Webasto in my FXT...
IIRC, you've had that since you first got the car. Had any problems with it? Leaks?
Re: MFin sunroof
Posted: Sat Jun 07, 2008 1:14 pm
by ElZorro
WRXWagon2112 wrote:ElZorro wrote:I have an aftermarket Webasto in my FXT...
Yea, it was 'dealer installed' (contracted out to Seatco in Arlington) prior to pickup. No leaks at all. Only problem I've ever had (and I'm having right now) is you have to reprogram it after a dead battery. There is a certain sequence and I always forget...
Re: MFin sunroof
Posted: Sat Jun 07, 2008 10:59 pm
by moxnix
ElZorro wrote:There is a certain sequence and I always forget...
Try Up, Up, Down, Down, Left, Right, Left, Right, B, A.
Re: MFin sunroof
Posted: Sun Jun 08, 2008 7:03 pm
by ElZorro
Thats the first thing I always try... I got 30 extra lives and skipped to the last level, but the bitch still doesn't work right
Re: MFin sunroof
Posted: Mon Jun 09, 2008 3:28 pm
I never wanted a sunroof on my foz but didn't know it came w/ one from the factory until I went to Richmond to pick it up. You know the subaru site keeps on those things w/ up to date info
I have used it twice since owning. I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
Re: MFin sunroof
Posted: Mon Jun 09, 2008 4:04 pm
by WRXWagon2112
sirwilliam wrote:I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
Based on my experience with a sunroof/moonroof in my VW Golf, I think those kinds of fears are no longer valid. Designers and engineers now have a good handle on sunroof/moonroof design so unless you do something stupid like take a knife to the seals it won't leak and the motor won't burn out.
Re: MFin sunroof
Posted: Fri Jun 13, 2008 11:20 am
WRXWagon2112 wrote:sirwilliam wrote:I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
Tell that to the people that had theirs leak and/or their motor go out on them...and these are newer subies. A motor will always go bad at some point as will most seals ...but when is the question (yes, there are standard maintenance procedures to prolong and, yes, newer products are made/designed to last longer). I just didn't want to have one more thing to worry about but I didn't have a choice in the matter.
Re: MFin sunroof
Posted: Fri Jun 13, 2008 10:01 pm
by moxnix
If I have a sunroof on a car I am going to use it. Would you not use the A/C because it might go bad? Or be afraid to drive on your tires because they might wear out? I would be more worried about seals that are never used than ones that get used more often.
My contour had a known issue with the sunroof motor gears but I still used it and never had problems with it.
Re: MFin sunroof
Posted: Sat Jun 14, 2008 10:02 am
I <3 my sunroof
Re: MFin sunroof
Posted: Wed Jun 18, 2008 6:31 pm
moxnix wrote:I would be more worried about seals that are never used than ones that get used more often.
Exactly my thought on the topic!
