MFin sunroof
- spazegun2213
- teh Spaz
MFin sunroof
you know, I 've never had a sunroof till i got the bimmah. Once i had one, i loved it, i leave it open to vent hot air during the day and its nice and cool when i get in it after work. But today, like so many days I've had to run though the pouring rain. So now I'm soaked, and all in the name of trying to save my car from becoming a fish bowl. Now i remember why I hate sunroofs!
Re: MFin sunroof
Manual convertible top ala Miata is the only way one should deal with the sun in a car.
IMHO.
Sorry you got soaked.
IMHO.
moxnix
- Tricycle
Re: MFin sunroof
Of course if you leave those down in the rain you have even more water to deal with.complacent wrote:Manual convertible top ala Miata is the only way one should deal with the sun in a car.
moxnix - still wet from leaving the top down yesterday.
Re: MFin sunroof
I miss having a sunroof like no other, but I also always made sure as hell to close it if I knew it was even going to sprinkle!
I did however, go off roading one day with the sunroof open on my Jeep.... Ya, it was interesting when muddy water came flying in through the sunroof!!!
Re: MFin sunroof
ha, d'oh!
i do miss the t-tops on my mr2. ah well.
Re: MFin sunroof
I have an aftermarket Webasto in my FXT... automatically closes when you turn the car off, and if you don't want it to you hit one button and it stays open.
Re: MFin sunroof
IIRC, you've had that since you first got the car. Had any problems with it? Leaks?ElZorro wrote:I have an aftermarket Webasto in my FXT...
Re: MFin sunroof
Yea, it was 'dealer installed' (contracted out to Seatco in Arlington) prior to pickup. No leaks at all. Only problem I've ever had (and I'm having right now) is you have to reprogram it after a dead battery. There is a certain sequence and I always forget...WRXWagon2112 wrote:IIRC, you've had that since you first got the car. Had any problems with it? Leaks?ElZorro wrote:I have an aftermarket Webasto in my FXT...
moxnix
- Tricycle
Re: MFin sunroof
Try Up, Up, Down, Down, Left, Right, Left, Right, B, A.ElZorro wrote:There is a certain sequence and I always forget...
Re: MFin sunroof
Thats the first thing I always try... I got 30 extra lives and skipped to the last level, but the bitch still doesn't work right
Re: MFin sunroof
I never wanted a sunroof on my foz but didn't know it came w/ one from the factory until I went to Richmond to pick it up. You know the subaru site keeps on those things w/ up to date info
I have used it twice since owning. I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
Re: MFin sunroof
Based on my experience with a sunroof/moonroof in my VW Golf, I think those kinds of fears are no longer valid. Designers and engineers now have a good handle on sunroof/moonroof design so unless you do something stupid like take a knife to the seals it won't leak and the motor won't burn out.sirwilliam wrote:I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
Re: MFin sunroof
Tell that to the people that had theirs leak and/or their motor go out on them...and these are newer subies. A motor will always go bad at some point as will most seals ...but when is the question (yes, there are standard maintenance procedures to prolong and, yes, newer products are made/designed to last longer). I just didn't want to have one more thing to worry about but I didn't have a choice in the matter.WRXWagon2112 wrote:Based on my experience with a sunroof/moonroof in my VW Golf, I think those kinds of fears are no longer valid. Designers and engineers now have a good handle on sunroof/moonroof design so unless you do something stupid like take a knife to the seals it won't leak and the motor won't burn out.sirwilliam wrote:I have fears of it leaking and/or the motor dying so the less I use it, the better IMHO.
moxnix
- Tricycle
Re: MFin sunroof
If I have a sunroof on a car I am going to use it. Would you not use the A/C because it might go bad? Or be afraid to drive on your tires because they might wear out? I would be more worried about seals that are never used than ones that get used more often.
My contour had a known issue with the sunroof motor gears but I still used it and never had problems with it.
Re: MFin sunroof
I <3 my sunroof
Re: MFin sunroof
Exactly my thought on the topic!moxnix wrote:I would be more worried about seals that are never used than ones that get used more often.
