Can you comment on the physical differences between the SZ and the green?
Not really, they are basically the same TD-06H turbine with a 49lb wheel
Are you saying here that for the additional money between the 49 and the 55 (including the parts independent of the turbocharger) is only going to net 25hp?
The only difference between the FP green / SZ49 and the SZ55 is that the SZ55 has a 55lb wheel and the Green has a 49 lb wheel.
And yes, it's really only worth around 25 whp.
The
new HTA green uses a different cartridge than the standard FP Green (it also requires a 3" intake)
There is a write-up on the performance differences between the old FP Green and the new HTA Green here:
http://forums.nasioc.com/forums/showthr ... =HTA+green
And what level of boost is this? And how much of it is "under the curve"? I've seen videos of the kilo-hp Supras, and they're actually kind of mild until about 5000 rpm, when they absolutely explode. That's useless to me. I'm more interested in a linear progression of power than I am in peak numbers.
Most of the larger (FP Red, GT3582) will be very late spoolers. As I indicated they do not reach peak torque until past 5,000 RPMs, and all require lots of boost (26+ psi) and ideally meth injection or race gas to take full advantage of them. These will be similar to the Supras you are referring to above. If you want great throttle response at lower RPMs than a GT35R is
NOT for you.
The GT3582 is actually the one I thought had the most promise.
If your going to go GT35R I'm not certain I would bother with a stock location set-up. To take full advantage of the GT35R you will want a 3" intake which means intake, and turbo inlet (and a difficult install in stock location), a Big MAF, TGV deletes, custom up-pipe, down-pipe and FMIC tubing. There are several kits out there. Ultimate racing's sells for $3,600 which includes turbo, intake, up-pipe, down-pipe, wastegate and dump tube. The FMIC kit with tubing is another $1,650. The tubing sells for $350 and you can get your own core.
Honestly, if your thinking of this path, I would find a tuner you trust and find which set-up he likes and follow his recommendation.
Yeah, it is too much. The way I drive, if I had peaky performance, or a crushing onset of power, I'd lose the car pretty easily. I want to be able to pull out of turns, on the gas, and not have to worry about the car sliding off the road. And this is not mentioning the cost, of course.
Honestly, if Julian's is too much, than the (non-HTA) FP Green sounds like the right choice:
1. It's stock location and bolt's up w/o issue
2. You can keep your current intake and turbo inlet
3. You can keep your TGVs
Try to get a drive out of your buddy with the Green and see if it's the right amount of power for you.
Julian seems to be saying that the bigger tmic is mandatory.
I would agree with Julian, a bigger TMIC or FMIC would be a wise choice.
It should be pointed out that a GT30R (depending on the trim) is not much of an improvement over an FP Green.
Most plots I have seen of the GT3071 are very similar to the FP Green on pump gas @ 21-23 psi. They spool about the same with the GT30 getting a bit better top-end power in most cases, 10-15 whp on average.
However, a stock placement GT3071 is $1,895 from ATP and the FP Green is $1,399.
That $500 could pay for your down-pipe, headers and TMIC!
