Alienware curved display does 2880x900
WANT!!!
Unfortunately it's only a prototype right now but I'm saving up my pennies regardless.
Must... not... fap!
:shock: :shock: :shock: :shock: :shock:
Phibs
Post by Phibs »
woot 720p porn would look great on that!
dassa lossa pixelers.
zomg!!
:hitit:
sweeeeeet
Mr Kleen wrote:sweeeeeet
You talkin' 'bout the display or meeting Mrs. Parker in WoW?
http://www.youtube.com/watch?v=vq52x6LmUew
Interesting that it's actually a DLP and not a LCD. I'd take one... or three :)
scheherazade
Post by scheherazade »
Here's a little warning about super-wide displays (speaking from experience)
I have the matrox tripple-head-2-go.
You achieve basically the same thing as that alienware display :3x wide single display (made up of 3 linked separate displays, in my case).
Unfortunately, what manufacturers don't bother telling you is that most games have a fixed horizontal field of view angle.
For example, using a given game with a 90 degree horizontal field of view :
@ 5:4
If your display is 25" wide and 20" tall :
90 degrees of view in X
72 degrees of view in Y
@ 15:4 (tripple wide)
If your display is 75" wide and 20" all :
90 degrees of view in X (fixed horizontal FOV)
24 degrees of view in Y
So, with the tripple-wide, you're effectively blinded up/down.
(Because your up/down field of view is so small)
I was pretty disappointed...
*MOST* games had fixed horizontal FOVs.
The only game I had that actually had a fixed *vertical* FOV instead of horizontal, was CS:S.
All ID engine games let me adjust the horizontal FOV in the console.
WoW doesn't let you adjust the FOV's.
Though, you can zoom out in the config.wtf file, which helps somewhat.
I actually bought the TH2GO for WoW, and found out all the adds were misleading.
How the adds were made :
(Note : I got the matrox folks to admit this on their forum.)
The camera would zoom out, and take a screenshot.
Then they would crop off the sides, and use that remainder as the 'normal' screenshot. So it looked like you gained FOV using the TH2GO. But you really got vertically blinded :(.
Le'sigh.
What does this matter?
Well, a super wide screen like that will suffer the same thing.
You'll be vertically blinded.
And it's not a matter of "wide screen support".
"Wide screen support" only means that you will be able to select your resolution.
The issue is whether or not the game lets you peg your field of view to the Numerator or the Denominator in your aspect ratio. That is a developer choice/prerogative. Usually this is not an issue. It only becomes an issue when you're dealing with extreme cases, like a tripple-wide display.
Newer games will probably have this addressed to some extent. Just don't expect anything you already have now to give you a good ultra-wide experience.
-scheherazade
Post by WRXWagon2112 »
Interesting. According to this, WoW supports "super-wide resolution". (click on the picture at the bottom of the article)
Picture caption wrote:Games like World of Warcraft already work with a super-wide resolution, but the surround gaming utility can keep the interface from stretching out all over each display as you see here.
Maybe it only works with the DVI version?
Re: Alienware curved display does 2880x900
Looks like this thing finally has a price and a release date. The display (now being released by NEC) will be available in July and will set you back a cool 8 grand.
Would you like to know more?
I still want it.
Libra Monkee wrote:...and will set you back a cool 8 grand
I still want it.
*COUGH*
ewww. that's crazy. :notcool:
(i've been seeing what you've been doing)
:on2me:
I was wondering how long it would take.
Dear GOD that is a lot of mula....
I bet there is someone around that's spent that on mods for an STi.... :poke: :poke: :mrgreen:
:shock: :finger:
That....would be amazing for a driving sim setup. Fortunately I'm putting that money into building the GC :)
