Now with more Deatschwerks
Got the 740cc injectors in and have some logs up, no full pulls but I'm concerned the logs show me only hitting 11.83 AFR @ full boost on the narrowband:
http://bsd-unix.net/seitz/enginuity/Deatsch/
Any ideas/thoughts/comments?
Re: Now with more Deatschwerks
It's because the narrow band can't go any lower than thatPhibs wrote:Got the 740cc injectors in and have some logs up, no full pulls but I'm concerned the logs show me only hitting 11.83 AFR @ full boost on the narrowband:
- BryanH
- Unicycle
Sabre wrote:It's because the narrow band can't go any lower than thatDo some logs with a wideband if you can!
Check with the wideband and let us know the results.
Send me the Logworks logs w/ the wideband when you get them, and I'll look them over and compare them with the last set and see if I see any issues.
I'm not really fond of the enginuity logs. Hard to keep track of everything.
So, did the gas smell go away when the stockers went back on?
How long have the 740s been in? No gas smell so far?
The gasy smell seems to have gone away, still get exhaust in the cabin though w/ the vent on ONLY when i'm stopped though.drwrx wrote:Send me the Logworks logs w/ the wideband when you get them, and I'll look them over and compare them with the last set and see if I see any issues.
Just put the 740s on last night. I will check my Motul1 oil pan in a few... it better have not fouled up my candy oil.
