What would be the best setup if I wanted to go EWG?
I currently have a Cobb TBE.
UPipe and EWG
UPipe and EWG
- hotsam
- hotsam
Gruppe-S sells an external wastgate up-pipe with a tial wastgate for $399. You can also get a helix down-pipe with an External wastegate port already on it for $199 but it doesn't have a cat on it.
TurboXS makes on as well for $329 (no wastegate) but their's may have fitment issues with your down-pipe.
Are you planing to dump to atmoshere or are you going to custom fab a tube to your down-pipe?
Would the helix DP fit on my cobb midpipe? Basically I want to replace as little as possible... and maybe nothing if you guys don't think EWG is worth it.drwrx wrote:Gruppe-S sells an external wastgate up-pipe with a tial wastgate for $399. You can also get a helix down-pipe with an External wastegate port already on it for $199 but it doesn't have a cat on it.
Yes, the Helix dp should match-up to your Cobb cat-back.Phibs wrote:Would the helix DP fit on my cobb midpipe? Basically I want to replace as little as possible... and maybe nothing if you guys don't think EWG is worth it.
You do realize you have to have the internal wastegate on the 20G welded shut to use an external set-up?
An external wastegate usually adds another 15-20 whp depending on turbo set-up over an internal. You would also need a retune.
Yep I understand both partsdrwrx wrote:Yes, the Helix dp should match-up to your Cobb cat-back.Phibs wrote:Would the helix DP fit on my cobb midpipe? Basically I want to replace as little as possible... and maybe nothing if you guys don't think EWG is worth it.
