Would anyone know offhand the size of the bolts that connect the axelback and the midpipe? A friend needs to cut the rusty ones off and replace them to swap my exhaust.
Let me know. Thanks.
Note: WRX/STi/FXT are all the same.
Bolt size
Bolt size
14mm bolts... Every AutoZone/TrackAuto etc. carries them. Just look for this:
You are showing me the bolts for the donut flange juncture...but thanks anywaysSabre wrote:14mm bolts... Every AutoZone/TrackAuto etc. carries them. Just look for this:
It's 14mm bolt's down the entire exhaust... so I'm guessing you'd be good with a 14mm. Just curious... why does it matter? If you're replacing the nut/bolt anyway, just get something that fits and that is an 8+ so it won't rust.
