-STi 20mm RSB w/ larger mounts
-KB rear endlinks
-MoBoost LLWS
Here is a pick from Peaty (scoobymods) that has the same setup and it looks identical to: SCOOBYMODS PIC LINKY
You can see in the picture why the MoBoost supports (the black pieces) are needed due to the crappy weld on the rear lateral link tabs.
Hopefully, get the springs on this week...then maybe my F&R strut tower bars and then my new 18 RPF1s!
NOTE: After using my torque wrench to tighten up the bolts w/ absolutely no room/clearance, I decided next time to use rhino ramps
