I wouldn't normally make much of it, but I'm noticing three things that seem to be related.
First, for the last couple days, we've been smelling clutch. Not upon shifting, but rather while underway. At first, I thought it was somebody's ATF, or maybe even our brakes, but since it's persisted for the last few days, it seems to be us.
Second, both Sandy and I have lost traction in the last 24 hours, on the same kind of turn, a 90° left-hander, and at the same speed, 35-45mph. For her, she was in 4th, and had understeer, I was in 3rd, and had oversteer. But, given the same speed, and the same direction, I think I can safely assume the difference between over/under steer in this case is the difference in torque between 3rd and 4th (consider the RPM range difference given a similar speed). I had to correct for oversteer, she had to correct for understeer. This is, of course, an AWD car, so it's weird that we would have different reactions.
Third, the car seems to be a little mis-aligned, tending a little bit to the left. This seems to me to indicate that on a turn a little too "hot," the car might not behave as expected. I've certainly had the car in hard left-handers above 110mph, and not noticed anything odd until recently. We're at 9500 miles, and just had our tires rotated at 7500 miles (we were looking at houses, so put a ton of miles on the car in the last few weeks, without really "driving" the car). Is it possible that during the rotation we encountered some alignment mis-geometry?
Since we've both lost traction in the last 24 hours (and not before), is it possible that it's road conditions? They're mostly dry in Arlington, and the roads were the same (mostly dry asphalt). The only thing I can think of is that it's been cold-ish lately, with the last day or so being 70°F+. The tires are of course the stock tires.
I kind of think it might be a good idea to get the rear cambered out a little, and maybe to get some "real" summer tires (yes, I know, everyone has wood for the stock tires, but I'm thinking something along the lines of KV710 or YA032R). It kind of worries me. Since we're at 9500, and oil is due to be changed on Tues/Weds, I am considering just asking Don Beyer to have a look at the alignment, and if everything is in order, to dial in maybe 1-2° of negative camber out back. I'm not sure what to make of the clutch smell. Is it possible that a wonky alignment could lead to clutch mis-engagement? I haven't heard of such a thing, but then this is the first three-LSD vehicle I've owned. Is it possible that one of the differentials is unhappy? Don Beyer made a huge stink about getting the car in to have the tires rotated at 7500mi, saying if we didn't that we might throw a transmission.
Ideas?
clutch / alignment / tires?
Re: clutch / alignment / tires?
Strange, not sure what to tell you on this one!avriette wrote: First, for the last couple days, we've been smelling clutch. Not upon shifting, but rather while underway. At first, I thought it was somebody's ATF, or maybe even our brakes, but since it's persisted for the last few days, it seems to be us.
The differences in torque, tire temp and road conditions (asphalt temp etc.) could definitely make the turn seem different and cause different reactions in the car.avriette wrote: Second, both Sandy and I have lost traction in the last 24 hours, on the same kind of turn, a 90° left-hander, and at the same speed, 35-45mph. For her, she was in 4th, and had understeer, I was in 3rd, and had oversteer. ...
This it is possible they threw it out of alignment with the rotation (banging the wheels on and such), they would have to try REALLY hard to do this.avriette wrote: Third, the car seems to be a little mis-aligned, tending a little bit to the left. This seems to me to indicate that on a turn a little too "hot," the car might not behave as expected....
Since we've both lost traction in the last 24 hours (and not before), is it possible that it's road conditions? ...
Take a look at the Yokohama ADVAN Neova AD07's. They are one HELL of a tire. They are definitely not cheap (~190/ea), but I think they are worth itavriette wrote: I kind of think it might be a good idea to get the rear cambered out a little, and maybe to get some "real" summer tires (yes, I know, everyone has wood for the stock tires, but I'm thinking something along the lines of KV710 or YA032R). It kind of worries me. Since we're at 9500, and oil is due to be changed on Tues/Weds, I am considering just asking Don Beyer to have a look at the alignment, and if everything is in order, to dial in maybe 1-2° of negative camber out back. I'm not sure what to make of the clutch smell. Is it possible that a wonky alignment could lead to clutch mis-engagement? I haven't heard of such a thing, but then this is the first three-LSD vehicle I've owned. Is it possible that one of the differentials is unhappy? Don Beyer made a huge stink about getting the car in to have the tires rotated at 7500mi, saying if we didn't that we might throw a transmission.
Ideas?
BTW, the reason that they were so insistent is because differences in tire diameter can lead to diff wear and tare. I wouldn't think that after so few miles that would be an issue for you all though. The only times I have heard of that being an issue is when you have the spare tire on and drive it over 100miles.
As far as adding 1-2° of negative camber, you'll need to get camber bolts to get to 2°. Definitely check out PTuning (one of our sponsors) if you want to get anything but the "stock" alignment done.
Going to have the dealer look into this. I figure something could be misaligned, clutch-wise.Sabre wrote:Strange, not sure what to tell you on this one!avriette wrote: First, for the last couple days, we've been smelling clutch. Not upon shifting, but rather while underway. At first, I thought it was somebody's ATF, or maybe even our brakes, but since it's persisted for the last few days, it seems to be us.
Yeah. I've done a lot of alignments and tire rotations myself.This it is possible they threw it out of alignment with the rotation (banging the wheels on and such), they would have to try REALLY hard to do this.avriette wrote: Third, the car seems to be a little mis-aligned, tending a little bit to the left. This seems to me to indicate that on a turn a little too "hot," the car might not behave as expected....
I'll have a look. I hear there's a guy selling some rims.Take a look at the Yokohama ADVAN Neova AD07's. They are one HELL of a tire. They are definitely not cheap (~190/ea), but I think they are worth itBTW, I always found the stock tires to be a little to greasy for me, esp. when they warmed up.
So, I'd rather drop $800 on tires than continue to lose traction when going around turns.
This is good to know. Any idea whether Subaru will be pissed if we get that much camber in the car? Dodge was pretty unhappy when I brought the ACR in with -2 out back, told me I could void the warranty (on a FWD car!).As far as adding 1-2° of negative camber, you'll need to get camber bolts to get to 2°. Definitely check out PTuning (one of our sponsors) if you want to get anything but the "stock" alignment done.
I don't know why they would be upset with you on that one. It's not like they are going to warranty the tires, which is what that will wear out quickly.avriette wrote: This is good to know. Any idea whether Subaru will be pissed if we get that much camber in the car? Dodge was pretty unhappy when I brought the ACR in with -2 out back, told me I could void the warranty (on a FWD car!).
BTW, FYI: STI's come with one set of camber bolts up front and none in the rear. You can however add another set up front and some in the rear to get as much camber as you want. If you really want to go crazy, camber plates and bolts will let you go REALLY hard core... but I don't think you want to drive a car on the street setup like that
- spazegun2213
- teh Spaz
1) how much tread do you have left on the 70's (I'm looking for a set for cheap)
2) if you put v710's or another slick tire on your car, you will die. They are NOT street tires!!! R-comps are also a waste on the road as you'll eat more tread on your commute than you'll ever use in a corner. they are also expensive to boot.
3) Go to ptuning for an alignment, I'm 11ty billion % satisfied with mine and they went the extra miles to make sure the car was perfect (and let me know i could still add more camber to the front).
My current alignment is -2* F and -1* rear. Seems to be almost perfect for my driving style. The car rotates and turns on a dime, thus i cant wait to get her on the track with the hoosiers i just picked up
you will need ingals, whiteline, etc, 14mm style bolts in the front AND rear to get the settings i have. Talk to Hotsam as he generally has great deals on these. Once you have the bolts take the car over to pTuning and let them do the rest
your alignment will GREATLY improve tire ware, grip, etc so i would even recommend holding of on tires and until after you get an alignment.
