				sti/spt "blue" injectors?
				Posted: Wed Oct 11, 2006 6:26 pm
				by avriette
				I had heard from NASIOC that the STI "pink" injectors flowed better than the stock ones I have on my 06 STI. This ad from subaru:
https://www.subarugenuineparts.com/prod ... ts_id=1066
claims that these injectors are "as good" as the "pinks". Is that the case? Does anyone know what these actually flow? If they're the same, is it possible to get them tuned (say, by RC Engineering or whoever) to flow more (so as to be used with an AP, etc)?
				Posted: Wed Oct 11, 2006 6:47 pm
				Well, here is the thing.  You can take your stock STi/XT injectors.  Send them to
www.boxer4racing.com + $219 and they will send back Perrin 800cc modified injectors (which is what I installed yesterday in my XT...thanks again Julian).
Best bang for the buck.  If you still have to drive around w/ your stock injectors.  You can buy some used ones...which I just happen to have an extra set for $100 and so you spend $319 for 800cc injectors while still having the ability to drive your STi while you are waiting for the new injectors.
So it is your choice: spend $219-$319 or spend $500-$800 for injectors.
I think the right choice is obvious.
PM, if you want more info.
				Posted: Wed Oct 11, 2006 7:22 pm
				by avriette
I was wondering, actually, whether I could put higher-flowing injectors into the same housing as the stock injectors, so it wouldn't appear that anything had been changed.
				Posted: Thu Oct 12, 2006 7:12 am
Well, you send your stock injectors (or another set of stock injectors) out to get modified.  Yes, you have the stock injector housing but they are flowing much more...so in actuality they have been changed.
Wait, in housing do you mean where they seat in the engine block?
				Posted: Fri Oct 13, 2006 10:45 am
				The modified (Perrin) injectors are just stock injectors that have had their screens removed from the bottom of the injector.  The WRX injectors were fairly easy to modify yourself, but the STI ones are unfortunately not
Except for the flow (which goes from the 500's to the 800's), there is no difference between the modified ones and the stock ones.
FYI: The injectors you linked to above are top feed injectors, which are WRX specific.  The STI uses side feed injectors, so those blue ones would not fit in the STI.
				Posted: Sat Oct 14, 2006 9:03 pm
				The new top-feed injectors from subaru do flow about if not more than the STi "pinks".
				Posted: Mon Oct 16, 2006 11:19 am
				zaxrex wrote:The new top-feed injectors from subaru do flow about if not more than the STi "pinks".
I heard the new top feed injectors flow 650cc vs. the old top feeds that did 550cc.  Anyone else hear this or have proof?
				Posted: Mon Oct 16, 2006 1:55 pm
				Mebby, Hneah
Linky stinky
				Posted: Mon Oct 16, 2006 3:38 pm
So that one is MythBusted!!!
