I had heard from NASIOC that the STI "pink" injectors flowed better than the stock ones I have on my 06 STI. This ad from subaru:
https://www.subarugenuineparts.com/prod ... ts_id=1066
claims that these injectors are "as good" as the "pinks". Is that the case? Does anyone know what these actually flow? If they're the same, is it possible to get them tuned (say, by RC Engineering or whoever) to flow more (so as to be used with an AP, etc)?
sti/spt "blue" injectors?
Well, here is the thing. You can take your stock STi/XT injectors. Send them to www.boxer4racing.com + $219 and they will send back Perrin 800cc modified injectors (which is what I installed yesterday in my XT...thanks again Julian).
Best bang for the buck. If you still have to drive around w/ your stock injectors. You can buy some used ones...which I just happen to have an extra set for $100 and so you spend $319 for 800cc injectors while still having the ability to drive your STi while you are waiting for the new injectors.
So it is your choice: spend $219-$319 or spend $500-$800 for injectors.
I think the right choice is obvious.
PM, if you want more info.
I was wondering, actually, whether I could put higher-flowing injectors into the same housing as the stock injectors, so it wouldn't appear that anything had been changed.sirwilliam wrote:
Well, you send your stock injectors (or another set of stock injectors) out to get modified. Yes, you have the stock injector housing but they are flowing much more...so in actuality they have been changed.avriette wrote:I was wondering, actually, whether I could put higher-flowing injectors into the same housing as the stock injectors, so it wouldn't appear that anything had been changed.sirwilliam wrote:
Wait, in housing do you mean where they seat in the engine block?
The modified (Perrin) injectors are just stock injectors that have had their screens removed from the bottom of the injector. The WRX injectors were fairly easy to modify yourself, but the STI ones are unfortunately not
Except for the flow (which goes from the 500's to the 800's), there is no difference between the modified ones and the stock ones.
FYI: The injectors you linked to above are top feed injectors, which are WRX specific. The STI uses side feed injectors, so those blue ones would not fit in the STI.
I heard the new top feed injectors flow 650cc vs. the old top feeds that did 550cc. Anyone else hear this or have proof?zaxrex wrote:The new top-feed injectors from subaru do flow about if not more than the STi "pinks".
Mebby, Hneah Linky stinky
So that one is MythBusted!!!zaxrex wrote:Mebby, Hneah Linky stinky
