time for a new stance
- psuwrx
ok all. i've been collecting a few things over the last month:
prodrive springs
sti group-n strut mounts
and set to arrive on fri sep 1, some kyb agx struts.
my question is: is there anything w/in that set up that i might have overlooked? i read a little about camber bolts, but am not sure i if i need them for example
any input helps...
and ofcourse, i'm gonna need help puttin these badboys on, so...install day anyone?
prodrive springs
any input helps...
lights, lights, and more lights...
- psuwrx
full struts
parts:
734034
734035
734036
734037
as listed on the kyb site
http://www.kyb.com/catalog/index.php?Ac ... 7&x=44&y=8
parts:
734034
734035
734036
734037
Ya, next weekend we could do an install day on Monday or something
How much of a drop are you going to get with these? You'll probably need an alignment afterward and the camber bolts (and plates) will certainly help with that.
- GeneralGrievous
- psuwrx
i had figured on scheduling an alignment about a week after i dropped it. and probably getting some of the camber bolts too...to give you an idea of what is possible w/ the springs:
stolen from machv
http://www.fastwrx.com/prodsprin.html
labor day...i might be able to be in on it that day...my big problem is work these days...i'm working in nova now, and it seems they are taking officers for trips, which leaves lots of ot to be had by those left behind...ie:me...so i'm picking up what i can...
stolen from machv
Glad to hear you've already got the alignment in the works
I *might* be able to do some of the work on Sunday, but I have an engagement party to go to that night.
BTW, do you have spring compressors?
Where are Ben's spring compressors? Anyone know?
Zak (my roomie) has the air compressor
You don't need an air gun... I use my gear ratchet with an allen key and it works just fineMr Kleen wrote:spring compressors and an air compressor! you'll need an air gun to get the springs off the struts and to reassemble them. if you're replacing both you'll just need to assemble the new struts and springs, but you'll still need to same tools.
Ben's spring compressors are in my tool box in old town.
- spazegun2213
- teh Spaz
pfft amatures...
I have BOTH air tools AND spring compressors (barrowed though)
when's the date? Odds are I'll be working on my 944 anyway, i have some new toys for her
zaxrex wrote:So ass that the the air compressor and impact gun if you want.
- psuwrx
well, i have none of said tools.
and julian, as far as an sunday install...sat night the godsmack/robzombie/shinedown concert at nissan. which translates into late drinking...to be followed up by a housewarming party at my friend's place on sun...which will also involve more drinking...
this being said, labor day monday is still the best for me. otherwise, another data would have to be planned.
Oh, I thoguht you said Monday wouldn't work for you! I can definitely help you out Monday
I would be up for that if not the fact I will be in PA and that it is my wife and I's wedding anniversary...think it will be the second anniversary in a row that we can't celebrate properlypsuwrx wrote:anyone else in for monday?
- psuwrx
Some kits require you to cut them, not sure about yours
- psuwrx
ok, a little reading on the other site, and i found i can just reuse the original bumpstops...and a f ew other things too...
and julian, it wasn't a kit that i ended up buying...mix and match of new pieces more or less...the struts didn't include anything but the adjusting screwdriver and a sticker.
