Technical data
engine type: 2-cylinder 4-stroke boxer engine
valves: 4 valves per cylinder
capacity: 1130 cc
power output: 95 Horsepower @ 7250 RPM
torque: 72 Lb-Ft @ 5500 RPM
catalytic converter: controlled 3-way catalytic converter
transmission: 6 gears / 1 reverse gear
Mass and weights
tank volume: 4.75 Gallons
dry weight: 880 Lbs
overall length: 87.5 inches
overall width: 55 inches
Chassis
frame: GG-design-Billet Aluminum
wheel: individual wheel suspension with trapezoidal cross-members made of aluminum
suspension struts: Four-Wheel Independent A-arm Wishbone Shock Absorber
spring travel: 4 inches front and rear
drive: Shaft drive to rear differential
brakes: hydraulic brake system, 270 mm floating brake disks, 4 wheel- 4 piston GG brake calipers
wheels: OZ alluminum cast wheels 16 inch x F; 17 inch x R
tires: front: 195/40-16 rear: 225/40-16
Price Base MSRP $49,500.00
Performance
top speed: 115-plus MPH
0-60 in 4.9 secs
1/4 mile in 14.0 sec @ 91.8 mph
60-0 in 115ft
Figure 8: 25.8 sec
Skidpad, 200-ft dia.: o.90g
http://www.gg-quad-northamerica.com/
