After loosing various nut's and bolts, I've had to find replacements. I wanted to establish a way to keep track of the replacements. Here that is
Subaru:
12MM (back of turbo and most of exhaust):
. AutoZone - Dorman (Keep Tite) - M10-1,25mm Fine (NT5880) - ~$2
XXTuning Uppipe EGT plug:
. AutoZone - Dorman (Keep Tite) - 7/16"-20 x 1-1/2 (Too long, try
. 1/2 if possible) - CS1346; This is also 1,1mm-20x3,8cm
Notes:
The Grade 8 bolts (standard) are proof tested to 120,000 PSI (~820Mpa) and the Class 8.8 metric bolts have a minimum tensile stress of about the same. Grade 8 bolt heads have a 6-armed radial hash mark and the Class 8.8 has 8.8 on the heads.
If the head doesn't have any marks, it might be a Grade 2 bolt with about half the tensile strength and will corrode/gall faster.
Feel free to post ones that you have found
