Quick cooling question...
I know using redline water wetter in cold climate is bad, but I can't remember exactly what bad happens when you do...can someone enlighten me? thanks.
I seem to remember that WW is a surfactant and does most of its majic by reducing the surface tension of the water. This lets smaller bubbles form on the internals of the radiator giving the liquid much more surface arae to exchange heat with.
I do not believe that it is an anti-freeze, and it may even raise the freezing temp of the coolant.
I can remember reading about a guy that had problems with the WW seperating from rest of the cooland and making an oily film. That may gell up and block some passages.
I would say get a strip of aluminum, distilled water, and a bottle of WW and stick it in the freezer and see if anything happens...
and let us know what happens!!!!zaxrex wrote: I would say get a strip of aluminum, distilled water, and a bottle of WW and stick it in the freezer and see if anything happens...
- spazegun2213
- teh Spaz
Re: Quick cooling question...
Umm, if the water freezes, you are FOOKED, my friend just split his GSXR-1000 engine block keeping that stuff in for the winter.sirwilliam wrote:I know using redline water wetter in cold climate is bad, but I can't remember exactly what bad happens when you do...can someone enlighten me? thanks.
other than that.. i dont know. But thats a BIG oops!!
But that is if you are running water w/ WW in it w/o anitfreeze, correct? I am pretty sure there is no water in the WW.spazegun2213 wrote:Umm, if the water freezes, you are FOOKED, my friend just split his GSXR-1000 engine block keeping that stuff in for the winter.sirwilliam wrote:I know using redline water wetter in cold climate is bad, but I can't remember exactly what bad happens when you do...can someone enlighten me? thanks.
Yes, it is used in addition to antifreeze...it says so on the back of my bottle. It works best mixed w/ 100% distilled water but that is not good for cold climates. Talked to a buddy of mine, Peaty, who wrote me:Mr Kleen wrote:water wetter is an adaptive to water (distilled) for the cooling system. it is used instead of antifreeze in cars that don't see freezing temps (race cars, drag cars, SoCal cars). I don't think it's used in addition to antifreeze, but I could be wrong.
I can't see why WW would be bad in colder climes. I've been using it for years and it gets pretty cold here. We've seen below -6F (-21C) with no issues.
He is also the one who gave me the above link.
Here is the redline link on the WW:
http://www.redlineoil.com/products_coolant.asp
- spazegun2213
- teh Spaz
its not BAD in winter climates unless you do water and WW. If you have enough antifreeze i think you will be ok, but in the winter why worry about adding that stuff? may as well save it for the summer when cooling is a bigger issue...
oh, but if you DO try it, let me know how you like it!!!!
Yes, I realize this. But if you put the redline in during the summer, you aren't going to replace your antifreeze 5 months later for winter.spazegun2213 wrote:
Will,
Yeah, I need to replace the antifreeze and then I will throw the water wetter in...this helps when outdoor temps are around 100+ degrees which hopefully the summer will not bring.
lol, you live around the DC area, so this is no longer a hope, it's a fact of life...sirwilliam wrote:this helps when outdoor temps are around 100+ degrees which hopefully the summer will not bring.
