Going for lowest possible TCO in a livable mobile.
Commuter of choice: Focus 1.0 SE 6MT.
They were trying to get rid of their manuals for significantly under invoice, so I obliged them.
Yup. Range per tank is actually 550-600 miles, but I pull off at 500 to see how much needs to go back in.drwrx wrote:50 mpg! Just image what you could get with a good tail wind and a gentle slope.
So you are only having to fill-up once a week despite the 80 mile round trip commute?
Had to leave her on the side of the road. Couldn't afford the weight. She'd also kept hitting me when we cornered, since in order to maintain momentum and keep mpg's up I slowed as little as possible.drwrx wrote:DAMN! I am shocked. I figured you would get some impressive mileage out of that mill, but 54 mpg is just amazing. That is putting-up serious Prius like numbers.
I guess I have to ask, How is Miss Daisy? I have to assume to get that kind of millage you are driving her.
I'm sure you can find ways of improve aerodynamic efficiency; tape, louvers, perhaps a front splitter?GaToR wrote:I drive the highway speeds, but don't go over 70mph because there's an accepted "aerodynamic wall" for the auto engineers I work with that above 70-72mph doesn't bode well for aero efficiency on road vehicles.
No thank you?drwrx wrote:I'm sure you can find ways of improve aerodynamic efficiency; tape, louvers, perhaps a front splitter?GaToR wrote:I drive the highway speeds, but don't go over 70mph because there's an accepted "aerodynamic wall" for the auto engineers I work with that above 70-72mph doesn't bode well for aero efficiency on road vehicles.
What is the Focus' coefficient of drag?
I'm sure with just a few hundred hours and a couple thousand of dollars I'm sure you can make the hypermiler even more slippery. Maybe even add another 1 even 2 mpg to the average!
I think the charge is part of the equation,Sabre wrote:VERY interesting on the mileage differences you are seeing. In other ways, it makes sense too: The colder charge is more dense entering the engine, which requires more fuel to keep at the stoic point. That doesn't change gearing though, so at the same speed you are using more fuel to make up for the denser charge.
Agreed, that's pretty awesome!drwrx wrote:Gotta say, 47.4 mpg is impressive!
Will be interesting to see how the Volt does.
Keep us posted.
