FreddyG's DD Build
Power:
93 Unleaded
382whp@5600RPM
374wtq@4300RPM
@22psi
E85 Ethanol
480whp@6300RPM
468wtq@4300RPM
@26psi
Engine:
Blue Printed & Honed 703 Block
Cosworth Rods
Cosworth Coated Pistons
Pinned & O-Ringed Block
Stock Subaru Crank
OEM Main Bearings
OEM Rod Bearings
Balanced Rotating Assembly
Killer B Oil Pickup
ARP Head Studs
TGV Deletes
Stock Springs
Stock Valves
Stock Cams
Intake/Exhaust/Fuel:
Blouch Dominator 1.5 XTR
Full Race Single Scroll Header
Grimmspeed EWG Ceramic Coated Uppipe
Cobb Catted Downpipe
AEM Intake w/DEI Gold Wrap
Process West TMIC w/DEI Gold Wrap & Ceramic Coating
Tial 44mm EWG
Air Pump Delete
Crawford Air Oil Separator
Perrin Turbo Inlet
Forge Motorsports BPV
COBB 3" Cat Back Exhaust
GrimmSpeed EBCS
Walbro 465 Fuel Pump Hardwired
Injector Dynamics 1000cc Injectors
Stock FPR
COBB AP Speed Density Tune
Drivetrain/Transmission
2011 WRX Transmission
Albins Rally Spec Gears 1-4/ OEM 5th Gear
Kartboy Shifter and All Bushings
Raceseng Apex R Shift Knob
Exedy HD Twin Disk Clutch
Exedy Lightweight Flywheel
Whiteline Transmission Cross member Bushings
Suspension/Wheels:
Work Emotion 11R Matte Bronze
Kics R40 Lugnuts
245/40R18 Dunlop Sports
RCE Yellow Springs
Koni Struts
Whiteline 22mm Front Sway Bar
Whiteline 22mm Rear Sway Bar
Whiteline Front Endlinks
Whiteline Rear Endlinks
2011 WRX Stock Wheels painted Tractor Green (Winter)
225/45R17 Continental Extreme Winter Contact (Winter)
GrimmSpeed Master Cylinder Brace
StopTech SS Brake Lines
Hawk HPS Brake Pads
ATE SuperBlue Brake Fluid
Interior/Electronics:
Defi Boost Gauge
Defi Oil Pressure Gauge
SMY Dual Gauge Cluster
AEM UEGO Digital Wideband O2 Gauge
Wideband Serial to USB Port
Omni Power 4 Bar MAP Sensor
JPM Coachworks Shift Boot
JPM Coachworks E-Brake Boot
JPM Coachworks Center Console
Subaru OEM Arm Rest Extension
OEM Subaru Foot Illumination
35% UV Window Tint
Super White LED Bulbs
Subaru Forester OEM HD Radio
Prova Wide-View Yellow Side Mirrors
Prova Wide-View Yellow Rear-View Mirror
Morimoto Elite HID System
Exterior:
V-Limited Front Lip (Winter)
STI Front Lip Extend Version (Summer)
Perrin Shorty Antenna
OEM STI Side Skirts
OEM Subaru Rain Guards
HT Auto Rear Spats
Grimmspeed Radiator Shroud
Killer B Alternator Shroud
Rally-Tech Dress Bolt Kit
DVNT Painted Headlights
OEM Blacked-Out WRX Side Badge
Grimmspeed Master Cylinder Brace
Car was built and tuned by Hill at Agile Automotive in Fallston, MD.
