Faster Than the Speed of Light?
Sadly NYTimes
Beyond the security gate at the Johnson Space Center’s 1960s-era campus here, inside a two-story glass and concrete building with winding corridors, there is a floating laboratory.
Harold G. White, a physicist and advanced propulsion engineer at NASA, beckoned toward a table full of equipment there on a recent afternoon: a laser, a camera, some small mirrors, a ring made of ceramic capacitors and a few other objects.
He and other NASA engineers have been designing and redesigning these instruments, with the goal of using them to slightly warp the trajectory of a photon, changing the distance it travels in a certain area, and then observing the change with a device called an interferometer. So sensitive is their measuring equipment that it was picking up myriad earthly vibrations, including people walking nearby. So they recently moved into this lab, which floats atop a system of underground pneumatic piers, freeing it from seismic disturbances.
The team is trying to determine whether faster-than-light travel — warp drive — might someday be possible.
Warp drive. Like on “Star Trek.”
“Space has been expanding since the Big Bang 13.7 billion years ago,” said Dr. White, 43, who runs the research project. “And we know that when you look at some of the cosmology models, there were early periods of the universe where there was explosive inflation, where two points would’ve went receding away from each other at very rapid speeds.”
“Nature can do it,” he said. “So the question is, can we do it?”
Einstein famously postulated that, as Dr. White put it, “thou shalt not exceed the speed of light,” essentially setting a galactic speed limit. But in 1994, a Mexican physicist, Miguel Alcubierre, theorized that faster-than-light speeds were possible in a way that did not contradict Einstein, though Dr. Alcubierre did not suggest anyone could actually construct the engine that could accomplish that.
His theory involved harnessing the expansion and contraction of space itself. Under Dr. Alcubierre’s hypothesis, a ship still couldn’t exceed light speed in a local region of space. But a theoretical propulsion system he sketched out manipulated space-time by generating a so-called “warp bubble” that would expand space on one side of a spacecraft and contract it on another.
“In this way, the spaceship will be pushed away from the Earth and pulled towards a distant star by space-time itself,” Dr. Alcubierre wrote. Dr. White has likened it to stepping onto a moving walkway at an airport.
But Dr. Alcubierre’s paper was purely theoretical, and suggested insurmountable hurdles. Among other things, it depended on large amounts of a little understood or observed type of “exotic matter” that violates typical physical laws.
Dr. White believes that advances he and others have made render warp speed less implausible. Among other things, he has redesigned the theoretical warp-traveling spacecraft — and in particular a ring around it that is key to its propulsion system — in a way that he believes will greatly reduce the energy requirements.
He is quick to offer up his own caveats, however, saying his warp research is akin to a university science project that is just trying to prove that a microscopic warp bubble can be detected in a lab. ”We’re not bolting this to a spacecraft,” he said of the warp technology.
Dr. White was an engineer with a background in the aerospace industry when he came to NASA in 2000, starting his career at the agency by operating the arms of space shuttles. He got his doctorate in physics from Rice University in 2008, and now works on a range of projects aimed at taking NASA beyond the fiery rockets that have long characterized space travel.
For NASA, Dr. White’s warp speed experiments represent a rounding error in its budget, with about $50,000 spent on equipment in an agency that spends nearly $18 billion annually. The agency is far more focused on more achievable projects — building the next generation Orion series spacecraft, working on the International Space Station and preparing for a planned future mission to capture an asteroid.
But it has made internal resources available for the project and freed up other engineers to assist Dr. White. It has also restored the pneumatic system in the laboratory Dr. White is using, to allow it to float. The lab was once used to test equipment for Apollo missions and has control panels underneath it that look like they belong in a fallout shelter that time forgot.
I want one! I doubt we'll see it in our lifetimes, but this give a glimpse of the future of space travel I think.
Re: Faster Than the Speed of Light?
Meh. Its all just a series of tubes anyways.
They have inductively sensed subatomic particles across known distances at times that would mean that the particle is exceeding the SOL. find a way to manage and direct the particles and set up the warp bubble.
done
Raven
Mr. Underpowered or something
Post by Raven »
This sounds a lot like how the fictional warp drive works, freaky.
But the real trick of the star trek universe was the warp core, the device capable of capturing raw energy and turning it into usable work. If we could capture energy like that we'd need like 10 nuclear power plants to power the world and we could probably make fusion work as a power source.
2013 Mazda 2
1994 Chevy S10 pickup
