so i decided to replace the rear wheel bearings in the RS...
supasixfo
Bicycle
Post by supasixfo »
and discovered that pre-2006 subies don't come with assembled bearings/hubs. $200 for bearing parts/seals. COME ON SUBARU?! really?! so i start taking apart the rear when i ... discovered that the trailing arm bolt is completely seized to bushings is seized to the lateral arms, you know what i'm talking about. that "big -ass bolt". well, that sucks, i guess i have to cut the bolt now and replace the bushings, except it's REPLACING BUSHINGS. EFF that ish (Electronic Frontier Foundation). i use the RS as a daily driver unlike the people on rs25.com which apparently like to remove, bush, and dip their lateral arms for funsies. new lateral arms it is. $250.
While i'm cutting the bolt, i need to un-rust the other bolts holding the lateral arms to the subframe. can't find them on rockauto, guess i need to go to the stealership LAWLAWLAWL $106 in bolts.
luckily, we have a press in the garage and i'm picking up a bearing puller. but i guess, while i'm back there, i might as well replace the brake shoes, and if we're re-doing the brake shoes, this might also be a good time to ...
STI SWAP STI SWAP STI SWAP.
This is how all my "should i fix it?" conversations go with the RS...
Alvin
Black Box rally team
Our blog: http://www.blackboxrally.com
Like us: http://www.facebook.com/blackboxrally
Re: so i decided to replace the rear wheel bearings in the R
Wow man. :)
LMAO, DO IT...
I have to say, my experiences with the L have been nothing short of great. The STI too has been easish to work on, except for things I caused, lol.
Just replaced my first wheel bearing on the STI at 179k. I took it to a shop, lol.
bearings are definitely on my list of "nope.jpg, straight to the shop with you!"
Yeah, had to replace one front left bearing at 60K and now a right rear is going at 99.6K.
Me no touchy
