I purchased a used APEXI white faced 60mm mechanical boost gauge over a year ago. Well, I recently noticed that the needle was sitting at 1psi unattached.
This means that I have a nice faulty gauge or is there a way to adjust it?
I guess I could check the boost readings and just see if it is just off by 1 psi which I can live with. I hate to loose the gauge b/c it is one of the better looking boost gauges out there.
							Boost gauge...
Boost gauge...
Thanks man...hopefully it isn't fugged 'cause that would suck. Guess there is only one way to find out.bluscooby23 wrote:Chances are it might be fuggered.
*crosses fingers for teh will*
