I figured I would post a PM that I had with Andrew to help others out there
Sabre wrote:
Idaho wrote:I believe a set of Cobb springs are on there currently with the stock struts. It's riding like ass and I am thinking it's possibly just bouncing off the bump stops. I'm pretty split between coil overs and a good strut/spring combo. I am just looking for a good street-able setup with maybe a 1" drop.
-Andrew
For coliover's, I cannot recommend the TIC SST's enough. I think that they ride better than stock and will get you the drop you are looking for.
If you're going to stay with the stock struts, you have a couple of options. I would recommend installing a set of grease fittings so that you can lube them periodically to avoid the dreaded clunk. http://www.iwsti.com/forums/gd-suspensi ... tures.html
For the drop you are looking for, take a look at the RCE black springs. I haven't tried them yet, but I think that is going to be what goes on the STI next (the TIC SST coil overs I have are going on my race car). http://www.racecompengineering.com/inde ... 04-07.html
I've never seen it done, but could you get away with using 02-03 WRX top hats and AGX struts on 05-07 STis?
It would be a much cheaper option than coilovers.
I know the 04 STi's (and 04-07 WRXs) will take AGX or Tokico D-Specs with strut spacers.
Hmm, that's an interesting idea! I don't know if it would work or not.
BTW, I love TiC's stuff and this package looks pretty decent!
