I am rubbing a bit in the rear and need to roll them. Does anyone have a roller or know where I can get them rolled?
Thanks.
Fender rolling?
goob_os101
Re: Fender rolling?
(gonna move this in here)
Re: Fender rolling?
If you are just rubbing on the lip, you can use a wooden bat and just roll it back and forth with some force and see if that does the trick before buying a delrin fender roller.
http://www.eastwood.com/pr-frrelease
Re: Fender rolling?
I'm sure if you call around there's a shop that will roll them for you. Maybe someplace will let you rent a fender roller?
I always thought that a fender roller would be a good "group buy" kind of tool.
Re: Fender rolling?
i swear i remember someone in mid-a over at nabisco talking about a community roller. might be worth asking there too, if you haven't already.
- LLTS1
Re: Fender rolling?
Also Use a heat gun or at least let the car sit in the sun and heat up first. Depending on how much you roll you may end up cracking the clear coat. Heating it up will help make it a lil more flexible.
Black 95 TSI
Re: Fender rolling?
There was someone on Craigslist that was renting one out. I think they where in Fort Washington.
