LED's efficiency exceeds 100%
Phys Org
The researchers, Parthiban Santhanam and coauthors from MIT, have published their study in a recent issue of Physical Review Letters.
As the researchers explain in their study, the key to achieving a power conversion efficiency above 100%, i.e., “unity efficiency,” is to greatly decrease the applied voltage. According to their calculations, as the voltage is halved, the input power is decreased by a factor of 4, while the emitted light power scales linearly with voltage so that it’s also only halved. In other words, an LED’s efficiency increases as its output power decreases. (The inverse of this relationship - that LED efficiency decreases as its output power increases - is one of the biggest hurdles in designing bright, efficient LED lights.)
In their experiments, the researchers reduced the LED’s input power to just 30 picowatts and measured an output of 69 picowatts of light - an efficiency of 230%. The physical mechanisms worked the same as with any LED: when excited by the applied voltage, electrons and holes have a certain probability of generating photons. The researchers didn’t try to increase this probability, as some previous research has focused on, but instead took advantage of small amounts of excess heat to emit more power than consumed. This heat arises from vibrations in the device’s atomic lattice, which occur due to entropy.
This light-emitting process cools the LED slightly, making it operate similar to a thermoelectric cooler. Although the cooling is insufficient to provide practical cooling at room temperature, it could potentially be used for designing lights that don’t generate heat. When used as a heat pump, the device might be useful for solid-state cooling applications or even power generation.
Theoretically, this low-voltage strategy allows for an arbitrarily efficient generation of photons at low voltages. For this reason, the researchers hope that the technique could offer a new way to test the limits of energy-efficiency electromagnetic communication.
Sounds like we need to re-evaluate some things!
Raven
Mr. Underpowered or something
Re: LED's efficiency exceeds 100%
Post by Raven »
I wasn't aware light had wattage. Lumens yes, watts no.
2013 Mazda 2
1994 Chevy S10 pickup
I think you are refering to two different things being measured.
The efficiency, usage or consumption is being measured in watts or in this case picowatts.
The output is measured in lumens.
The two usually are related. A high watt light usually has a high lumen level as well.
I think he was reading this
For us, the useful thing about light is that it illuminates things for us to see. So we measure that in lumens and stuff.
The photons are still energy, and how much of them pass onto an area in a time interval can also be measured in watts.
