underestimated the ice last night
FreddyG
- Bicycle
went around a corner last night a little to fast and hit the curb, rim still works with major curb rash but i noticed now my wheel alignment is slightly off. Is this a big problem? should i pay to get this fixed?
- USAF Ammo Troop
- USAF Ammo Troop
Re: underestimated the ice last night
Best case scenario: You have a little curb rash. Worst: You bent your control arm and damaged you rim.
I have a feeling that you just knocked your car out of alignment. Best thing to do is take it to a Subaru dealer (Don Beyer I would trust!) and have them realign it and check the control arm.
FreddyG
- Bicycle
thanks for the word of wisdom again julian
- USAF Ammo Troop
- USAF Ammo Troop
By wheel alighnment do you mean the steering wheel isn't straight when the wheels are, or do you mean the car doesn't track striaght? If the car isn't tracking straight, it is a wheel alighnment issue that will require going on a rack. If the steering wheel isn't straight with the wheels, you likely jolted the steering rack. That could be very cheap and easy, or quite pricey depending on the scenario. Either way, you will need to have a shop look at it.
Don't feel too bad, everyone who drives in inclimate weather has done something like this at some point.
thermobox
Yep, last time I did this was in my Prelude. I got lucky and knocked the aligment out.
I noticed my customers 2012MY WRX on the lift the other day. He did the same antics in the ice. The rim wasn't straight on the car. The tech was kind of scratching his head as to what component took the abuse. I noticed straight away that he had bent the rear subframe where the Lateral Link mounts.
Definately get it on a lift to see if there is anything outta whack. If all is good have the alignment done.
FreddyG
- Bicycle
the steering wheel just isnt straight i thought that was an alignment issue? cuz the car seems to still drive straight no pulling to either side
- USAF Ammo Troop
- USAF Ammo Troop
ResidentR
It's really hard to tell exactly what happened until you can get the car on a lift and have a good look around. I hope the car is ok, it doesn't sound too bad, and a dealer should be able to set you straight again.
I saw a G35 coupe today that looked like it slid around and bumped a curb too, but it's left rear wheel was probably 20 degrees of positive camber and about that much toe out, the tire squealing as he was driving it down 29 today.
Any alighment shop with a rack can tell you if you are out.
The steering wheel may be as simple as shifting the column or may require a steering rack adjustment.
FreddyG
- Bicycle
yea i got on it today probably 100 or so just to see if it vibrated and i felt no vibration at all, so i think its just a steering column issue, but i hit the back wheel not the front idk how that would knock the steering wheel out of alignment
- USAF Ammo Troop
- USAF Ammo Troop
That throws my theories out the window. Unless you had the wheels locked in one direction and managed to lift the front off the ground on the impact (thereby unloading the suspension and steering rack) and when it landed the stering wheel was still locked right (or left) while the wheels and rack had turned left slightly while unloaded. I haven't looked closely enough at a Subaru steering rack to know if this is possible.FreddyG wrote:but i hit the back wheel not the front idk how that would knock the steering wheel out of alignment
Ya, I assumed it was the front too. Best to get it looked at!
FreddyG
- Bicycle
got it checked out today by don beyer real quick today it was just an alignment issue nothing else is wrong thank god
- USAF Ammo Troop
- USAF Ammo Troop
