Engine isn't starting
Well, to follow up Zak's post about odd things...
The 95 Impreza L that I have would not start after I got back from a work trip. I turn the key, hear a click, but the starter doesn't even try to turn. I have checked:
Ignition fuse (as well as any others that I could find related to it).
Voltage getting to the starter (there is 12V going to the starter at all times, I presume it closes the ground loop to start it).
Battery (Replaced it initially thinking that was the problem)
Thoughts:
The starter is bad
Electrical gremlin
Here is the manual for the car.
Anything that I have not thought of?
Re: Engine isn't starting
Sounds like the ignition relay/solenoid.
the key switch hits a relay to close the bigger circuit for the higher current. You would not want your hand to be on the metal key that closes a 300 amp switch.
that link is missing the 6-2 2. ignition key switch section, skips straight to 11cruise control.
Funny you should mention the relay... I couldn't find the one for the ignition! I found tons of others, but not that one. I'm guessing, for whatever reason, that it is in a different place than the rest of them (looked under the hood at the "fuse" box and also under the drivers foot well). I'll go looking tomorrow for it since I won't be home till late tonight.
That is why you need section 6-2.2.
lol, thanks captain (obvious) ;) I'll go hunting today :)
Well that sucks. Lemme know if you're gonna beat on it this weekend, I got nuttin going on.
PGT
Post by PGT »
same here. I'll have time sunday after the morning
Well, I might do some today, not sure. I just need to find that damn relay/solenoid! NJow the STI has a NASTY exhaust leak... so that might mean that it is header/uppipe time... if it is, I might call on you all, haha.
PGT
Post by PGT »
I've got a garage and a portable A/C unit. Just sayin.....
PGT wrote:I've got a garage and a portable A/C unit. Just sayin.....
I would LOVE to work in your garage... but the car doesn't start to get it over there :lol:
Just let us know.
PGT
Post by PGT »
I was talking about the car that does work silly
PGT wrote:I was talking about the car that does work silly
:lol: I know, I just had to be a smart ass :)
