Brakes for the L
Brakes for the L
So, I'm gathering parts for the L project and have started looking at my braking options. My first thought was "Just grab a set of OEM STI Brembo's and go", but I've quickly learned that is a $1500 project! It looks like there are a couple of different options available to me. Here are a couple:
STI Brembo - 4 POT calipers, DBA rotors - $2200
Kido - 6 POT, 14" Kido rotors - $1700
Wilwood - 32lbs. of weight savings, forged 4-piston caliper, 11.75” vented rotors, SS lines - $2000
Stoptech - $2000
My god these prices are high :( Honestly, since the car will be so light, I'm really leaning toward the STI Brembo's.
Re: Brakes for the L
From your chart the Wilwoods are $1000 cheaper and 32 lbs lighter, so they would get my vote.
the stock sti clampers are heavy. if you want to minimize unsprung weight, i'd go with something else.
unless you can find a set of take-offs for cheap.
thermobox
Post by thermobox »
You can always do the Subaru 4/2 pots.
Actually, I needed to correct the Wilwood price... that was only for the fronts :( Price difference is $200 next to the OEM ones.
Complacent: I agree, but I actually worry about which would be able to dissipate heat better... is a heavier one better for this?
I seriously thought about going as cheap as I could... and then I remembered these things will be stopping me from stupid speeds.
PGT
Post by PGT »
Planning on 15" gravel wheels? Rallispec has brakes. Also...Outlaw makes a kit for MINI that fits 15" wheels but has extra thick rotors for heat capacity. Might be easy to adapt
Back when the Subaru 4 pot / 2 pot brakes became available on the 06 WRX, Sport Compact Car did a test of them vs the STi Brembos and the results were surprising.
SCC took an 06 STi and an 06 WRX, put the same wheels and tires and same pads on them.
The 40 mph-0 and 60 mph-0 stopping distances were nearly the same with the Subaru 4 pot / 2 pot set-up being slightly better over the numerous runs. The testers attributed this to the lighter weight of the Subaru components. The 80-0 and 100-0 favored the Brembos, but again, only marginally. The Brembos did tend to fade a bit less, but the testers thought this might be mitigated by better pads, fluid, rotors and lines.
That said, if this is going to be a dedicated track car going bigger is usually better. At stopping anyway, the added weight to the rotors can also negatively affect braking as well as acceleration.
thermobox
Post by thermobox »
KNS has a Stoptech kit.
^^^ Awesome, thanks Matt!
I actually need to pick a 2007+ STI for a car though since I'm replacing the hubs with 5x114 STI parts. Looks like they have a good price though :)
thermobox
Post by thermobox »
They have the same kits for 2005+ Sti's with 5X114.
Yep, sorry, I meant to mention that I had looked for that on that site and found it :)
I have a pair of 2005 STi Brembo calipers.
The rotors are up to you.
I also have a set of Mitsubishi (manufacturer, not car) one pots with bracket and rotors.
