It's still not very efficient, but every percentage helps!OAK RIDGE, Tenn., April 29, 2011 – With the creation of a 3-D nanocone-based solar cell platform, a team led by Oak Ridge National Laboratory’s Jun Xu has boosted the light-to-power conversion efficiency of photovoltaics by nearly 80 percent.
The technology substantially overcomes the problem of poor transport of charges generated by solar photons. These charges — negative electrons and positive holes — typically become trapped by defects in bulk materials and their interfaces and degrade performance.
“To solve the entrapment problems that reduce solar cell efficiency, we created a nanocone-based solar cell, invented methods to synthesize these cells and demonstrated improved charge collection efficiency,” said Xu, a member of ORNL’s Chemical Sciences Division.
The new solar structure consists of n-type nanocones surrounded by a p-type semiconductor. The n-type nanoncones are made of zinc oxide and serve as the junction framework and the electron conductor. The p-type matrix is made of polycrystalline cadmium telluride and serves as the primary photon absorber medium and hole conductor.
With this approach at the laboratory scale, Xu and colleagues were able to obtain a light-to-power conversion efficiency of 3.2 percent compared to 1.8 percent efficiency of conventional planar structure of the same materials.
80% Improvement In Solar Cell Efficiency
Science Blog
Re: 80% Improvement In Solar Cell Efficiency
oof. man does solar have a long way to go.
Solar works for limited applications.
It will be some time before it is efficient enough to be used as a primary heating or cooling source for a home, but it can help.
The next big hurdle is cost/benefit. Nobody is going to invest $30k into a solar system for their house with the breakeven being 40+ years out.
Perhaps when the efficiency improves 200% while cost drops 50%?
Solar is not PV. PV has a long way to go, but that is a subsection of solar energy. The easiest thing to do with solar is to heat water/construction mass.
While PV does not have a high conversion rate, solar water heaters and radiant heating are used the world over, just not here. They are very effective, cheap, and take a substantial portion of home heating energy usage away.
I've known several folks who have solar water heaters and have been impressed.
However, I've never seen a real breakdown of the cost per year of a gas or electric water heater vs. the total cost of the solar units.
a good step in the right direction.
