I getting one of these. *whips out the almighty Visa debit*
Sunforce 50022 5 Watt Solar Battery Charger
Solar Powered Trickle Charger
Re: Solar Powered Trickle Charger
if i parked anywhere near a place that got to see sunlight, i'd consider it.
as it stands, mah bonk sleeps in the dark at home and ad work.
Grrrr... You and your logic. Well if I set up a series of mirrors... ... ... ... nah.
Legend style?Libra Monkee wrote: Well if I set up a series of mirrors...
Just realized this is DC1WD and you're talking about a bike... ignore the above (well, not completely, because its still useful info, just not relevant to this conversation)Works great on the Chevy. Tricky on the FXT. Difference is that on the Chevy the cigarette lighter is always connected, on the FXT its disconnected when the car is off. Mine came with battery clips, so I'll clip to the battery, run the wire outside the back corner of the hood into the edge of the drivers door and then put the panel on the dashboard.
Yeah, I bought one for the WRX but it didn't work.
