Lifesize Paper NSX racecar
scheherazade
Re: Lifesize Paper NSX racecar
Post by scheherazade »
I just through of a sweet way to use this as a way to make a go-cart body kit (or a tube frame body kit).
Make the cardboard body
Spray it with varnish
Lube it up
Cover it with epoxy and fiberglass (making a negative mold)
Pull it off, and re-lube the inside of the mold
Line the interior with epoxy and fiberglass
Peel out your new body kit.
Sand
Paint
Win!
-scheherazade
That must have taken forever. And what does one exactly "do" with a life-sized paper replica car?!?
Page 2983
Assemble Instructions, Cont.
Insert Tabs 457-587 on sheet AZZRF1 into slots 963-1093 on sheet AZZPS12.
Secure joint temporarily with T-pins and re-enforce with a thin layer of adhesive.
Repeat with sheets AZZRF2-40 and AZZPS13-51
Let dry
^^^^ :rolllaugh: :rolllaugh:
