Need gauge wires and sensors. I found a great deal on 3 omori gauges (boost, EGT, oil pressure), but there are now wire or sensors. Gauges are from a totaled car and the guy had no time to fidh out the wires so un lipe them from the clock pod where the gauges were installed.
Any idea where/how much it would be to get new wires & sensors?
goob_os101
thermobox
Re: Need gauge wires and sensors
no clue. i don't know if this would be a good deal even if they were free. most every gauge comes with specific wire, sensors, bracketry, etc. sounds like it's more work than it's worth.
FYI, EGT's gauges arevery sensitive to wire length. They opperate on resistance, so different lengths of wire will affect them. They are calibrated at the factory with the wire that they come with. Make sure to use thermocouple wire when you do wire them up, as it has very little resistance. If you want it 100% correct though, you'll probably have to send it back to the factory and have them replace the wire and recalibrate it.
